speedo accuracy - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-27-2009, 06:30 PM   #1 (permalink)
Favourite Bike: TRIUMPH THRUXTON
Other Motorcycle: TRIUMPH TR5T
speedo accuracy
What do folks reckon to speedo accuracy on the Thruxton ?
I've been cruising at an indicated 80mph , but it doesn't actually feel that fast
jimmy nod is offline   Reply With Quote
Old 06-27-2009, 06:48 PM   #2 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
most read 4to6 mph faster then you are running
mikeinva is online now   Reply With Quote
Old 06-27-2009, 08:12 PM   #3 (permalink)
Favourite Bike: Thruxton
A coincidence in timing here: the other day I approached a speed indicator kindly set up by the cops. It showed 38 mph; my gauge showed 40. I'll have to check it a few more times, but I was going at a steady rate.
davidc is offline   Reply With Quote
Old 06-27-2009, 11:47 PM   #4 (permalink)
Favourite Bike: 09 Triumph Bonne T 100
Other Motorcycle: BMW R1100RT w/EZS sidecar
Smile speedo accuracy
Be careful here. Don't know about my Bonny's speedo yet but I do know that my '99 BMW R1100RT w/EZS sidecar varies as to how many mph faster shows when compared to my gps. At lower speeds like 20 mph the speedo shows 22 mph, gps shows 20 mph. At 60 on the speedo the gps shows about 55 mph. At 70 mph on speedo, gps shows about 62 mph.
Don't know why this is happening but I trust the gps and use it for my speedo. The R1100 has been modified with auto wheels/tires on all three points, now running 15 inch tires, not the 17 inch cycle wheels/tires that it originally came with.
Enjoy the day.
Karl
jkmolt is offline   Reply With Quote
Old 06-28-2009, 02:59 AM   #5 (permalink)
Favourite Bike: Can't decide now!!
Ventura's Avatar
Other Motorcycle: Scram + Thrux
Extra Motorcycle: '71 BSA Thunderbolt
There's another current thread on this very subject going on here............
http://www.triumphrat.net/twins-tech...libration.html
V.
2006 Scrambler, VARK'd, 155/40, 790 In-cam, Pieman'd igniter, DNA Pods, Zard 2:1.
2005 Thruxton, Black now, with ARK, FCR 39's & Uni's, Retimed 790 cams, Barnett clutch and suchlike!!
Ventura is online now   Reply With Quote
Old 06-28-2009, 06:32 AM   #6 (permalink)
thanks for the link, just realised my bike has a 17in front wheel which I presume will compound the problem
Old 06-28-2009, 07:04 AM   #7 (permalink)
Favourite Bike: 08 Triumph Bonneville
Bath Bonne's Avatar
I've never known an accurate speedo on any make of bike or car, I use a sat.nav against mine and at 70+ its about 3 mph fast, not so much on the lower speeds so watch out on the town Gatso's.
One of the more accurate ones Ive had.
Bath Bonne is offline   Reply With Quote
Old 07-07-2009, 09:21 PM   #8 (permalink)
Favourite Bike: mine
boofhead's Avatar
The thing that i find strange is blokes tell me when checking there speedo against the GPS reading they say the odometer reads correct , now i can not work out how if your speedometer is out than you odometer should be out the same amount
Am i wrong ?
what goes round comes round
boofhead is offline   Reply With Quote
Old 07-07-2009, 09:46 PM   #9 (permalink)
Favourite Bike: '07 Thruxton (de-clipped)
Knave of Clubs's Avatar
When speedos are off (which every bike I've ever had is), they are always off by a percentage, not a static amount. It just has to do with the ratio between the speedo ring or gear (depending on the kind of speedo sensor the given bike has) and the OD of the tire. So, that's why a speedo that is off by 1-2 MPH at 20 MPH can be off by 5 MPH or more at 80 MPH.
I don't know for sure why MC speedos are always off by a larger percentage than car speedos. My guess is that moto manufacturers know that there is a much greater likelihood of variability in the ultimate OD of the wheel and/or tire that will be run on a given model of bike across all of its owners out in the world compared to a car, where people very rarely go with anything different than what came on it. There are hefty fines for installing a speedo that reads low, so I suppose the err on the side of caution and make them all read about 5 percent high to give them a safe margin or error.
Knave of Clubs is offline   Reply With Quote
Old 07-07-2009, 09:52 PM   #10 (permalink)
Am i wrong ?
Yes, you're wrong.
The speedo and odo may run off the same sensor (and on some bikes, they actually have different sensors , but this is rare), but they are attached to different inputs (gears in the case of analog instruments like our bikes) at the instrument end. It's just a matter of calibration - what one rotation of the wheel translates to on the other end.
I had a KTM that had a digital speedo and odo, and an adjustable front-wheel setting among 17", 19", and 21". If you had it on 21", the speedo would be 5 percent fast, but the odo would be spot-on. If you set it to 19", the speedo would be spot-on, but the odo would be 5 percent slow.
Speedo accuracy - '69 vs. '09 Scrambler57 Twins Talk 7 12-17-2008 06:53 PM
Speedo accuracy donnieblaess Sprint Forum 9 05-15-2008 10:12 AM
Speedo accuracy dnyman Twins Technical Talk 13 08-17-2007 02:55 PM
speedo accuracy on S4 rainman_au Triumph SuperSports 6 11-03-2005 11:26 PM
Speedo accuracy piggydude Tiger Chat 9 05-09-2005 05:15 PM
