Numb hands! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-27-2009, 02:14 PM   #1 (permalink)
Favourite Bike: 09 SE
MuckSavage's Avatar
Numb hands!
My hands go numb very quickly after riding on my SE. I have some handlebar risers on order, and I am probably going to put a 19t sprocket in to help with the vibration. I know the seat height isn't helping me either, does anyone have any suggestions for me for riding position? I am 6'2 and while I don't feel cramped, I do feel a bit scrunched.
MuckSavage is offline   Reply With Quote
Old 06-27-2009, 02:48 PM   #2 (permalink)
Favourite Bike: Bonneville 07, "Bonnie"
koifarm's Avatar
Other Motorcycle: Past rides, 66 bonneville
Extra Motorcycle: Past rides, 72 bonneville
Buzzed out
You might try any of the vibration dampers available like bar snake, or similar, some guys fill the bars with lead shot, also bar end weights all seem to help somewhat, try that with your current setup if it's a comfortable ride.
Depending on your model of bike, the bar snakes will be stopped by the little dimple in the bend, might want to see if you've got a clear shot all the way through.
Changing your ergonomics may also help, perhaps a combination of several things might help.
Sitting on a cornflake waiting for the van to come!
koifarm is offline   Reply With Quote
Old 06-27-2009, 04:15 PM   #3 (permalink)
Favourite Bike: 2010 Thruxtonised Bonnie
Sofiaspin's Avatar
Other Motorcycle: '65 Velo Venom Clubman
Extra Motorcycle: 55 T100 racer
You can also go 'the other way' as many have done by:
1. Fitting M bars or in other words lower bars. The SE bars rake back more than bonnie's of earlier years and it sounds like you are looking to lean back more
2. Fit semi rearsets so your legs go back and your body forward with the bars above
The other option is to - sorry - change your bike for a t100, Thruxton or Scrambler, all of which have higher seating positions. Frankly, I think you are quite tall for an SE, which is aimed at a smaller rider (amongst other reasons).
Sofiaspin is offline   Reply With Quote
Old 06-27-2009, 06:02 PM   #4 (permalink)
Favourite Bike: 1970 Triumph TR6R
McBike's Avatar
Other Motorcycle: 2007 T100
Extra Motorcycle: 1969 Bonnie Basket
I have found that a major cause of numb hands is too tight of a hold on the grips. Try an relax and concentrate on using a lighter touch.
Mike
2007 Black / Red T100 AI removed, Hella H4 "E" Class Headlight, Feked Toga style mufflers 118 mains 40 pilot 2 3/4 turns out, Dual Star heated grip kit.
First Bike: 1966 Yamaha YL1 Twin Jet
The older I get, the faster I went.
McBike is offline   Reply With Quote
Old 06-27-2009, 06:20 PM   #5 (permalink)
Favourite Bike: 08 Bonneville T100 C/S
wenzel850's Avatar
Other Motorcycle: 05 T100 R.I.Pieces
If you decide to go the Bar Snake route us the liquid one. It is easier to put into your handlebars.
Also the easiest way to reduce vibes is make sure your bolts holding the handlebars onto the triple tree are torqued to Triumph Specs.
On my 2005 T-100 its 27 Newton Meters of torque, and use Blue Loctite on those bolts.
Quentin
wenzel850 is offline   Reply With Quote
Old 06-27-2009, 06:24 PM   #6 (permalink)
Favourite Bike: 2009 Street Triple R
Pokeyjoe's Avatar
Mike
+1. No one else has seriously complained about vibrations on Bonnies. Relax...
John
3-7-77
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is offline   Reply With Quote
Old 06-27-2009, 07:24 PM   #7 (permalink)
Favourite Bike: '09 SE
Blue09SE's Avatar
Other Motorcycle: '69 TR6R
RE: seat height on '09 Base and SE
I am 6'1"/250 lbs. After my SE test ride, I felt that while the bike was generally comfortable, a seat about 1" higher would be just right. The dealer had an example of each of the '09 models; the
'09 T100 seat, compared to the stock SE seat, is about 1" higher. The dealer's mechanic swapped the seats. This seat height permits me to keep my knees at about a 90 degree angle to my thighs, with my thighs parallel to the ground. I find this position to be comfortable for extended riding.
I would like to add another 1" of seat height, but would like re-use the entire stock seat cover, if possible. One upholstery shop proposed cutting off the stock seat cover's side panels, and re-using only the top of the cover. The seat cover is stapled to the base, and it looks like there might be enough material to unstaple the cover, add a small amount of extra padding (maybe 0.75"-1"), and restaple it a bit closer to the edge of the material.
Has anyone suceeded in adding such padding while retaining the entire stock seat cover?
Blue09SE is offline   Reply With Quote
Old 06-27-2009, 08:39 PM   #8 (permalink)
Favourite Bike: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
you also have to taken in consideration, roads, the weak suspension, and death griping the grips. If relaxing doesnt help all that much, superbars from New Bonneville and Manic Salamander end weighs... pretty much ended all vibrations
killian101 is offline   Reply With Quote
Old 06-27-2009, 10:59 PM   #9 (permalink)
I had the same issue, so I tried Grip Puppies from California Sport Touring. They are very inexpensive, easy to install, feel terrific, and they greatly reduce vibes to your hands. Also, because they are easier to grip, you don't have to hold on as tightly, thereby easing the tension in your hands and wrists. Anyone who sits on my Speedmaster, and grabs the handlebar grips, immediatly fall in love with the feel, and ask where I got them from. You will love them, and you will get them very quickly from California Sport Touring.
Here is the link:
http://www.casporttouring.com/store/...y_Code=GRIPPUP
singring is offline   Reply With Quote
Old 06-28-2009, 08:35 AM   #10 (permalink)
Als
Favourite Bike: EFI Bonnie Black
Try ear plugs! I had very numb hands on one of my earlier bikes and after trying everything else I finally put in ear plugs. I found it relaxed me just enough that I stopped gripping so tightly.
And since they only cost a dollar or so and are easy to get, I'd say try them first.
Als is offline   Reply With Quote
Hands going numb shoen Sprint Forum 40 06-23-2008 05:03 AM
Numb hands on Bonneville. Tips? mistermellow001 Twins Technical Talk 12 06-10-2007 10:31 AM
Numb Hands (2000 TBS) timritaharry Hinckley Classic Triples 20 05-02-2007 02:15 AM
Numb hands Antny Twins Talk 19 03-23-2007 10:56 AM
numb hands - what for relief KLH Sprint Forum 13 04-22-2005 03:19 AM
