2 Questions From The Newbie - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 06-26-2009, 07:15 AM   #1 (permalink)
Favourite Bike: '02 Bonneville
Dan in Cibolo's Avatar
Thumbs down 2 Questions From The Newbie
I could use some veteran advice on this one ...
'02 Bonneville:
1. My speedometer light's not very bright at night.
What bulb should I use for a brighter display?
I hear owners talk about LED bulbs.
2. Down the road, I'd like to buy David's "D9"
flat bracket. My '02 didn't come with a tach.
If I buy one, how difficult would it be to connect?
3. While driving, my steering seems very
touchy. If I just tap either end of the handlebar,
the bike responds too much, I think, and wobbles
(slightly) immediately. I can't remember
my other cycles being so touchy. I'm wondering
if I might have a bushing or bearing on the front
end going bad?
I really appreciate the advice given in this Forum.
There's nothing like being supported by a band
of brothers with similiar interests : ...
Finally got the right photo, in the proper size ...
Dan in Cibolo is offline   Reply With Quote
Old 06-26-2009, 09:12 AM   #2 (permalink)
Favourite Bike: 02 Bonneville
ivar's Avatar
Other Motorcycle: 93 Dnepr MT-16
Extra Motorcycle: 05 SV650S
#2: D9 bracket: Just got done installing mine - but not connected the tach yet.
The D9 kit is geared towards those who have twin gauges. Converting from a single gauge setup, you'll need some more parts.
Best bet is to start looking for a tach retrofit kit, around $280 on ebay to avoid getting nitpicked on the small parts.
I bought a tach separately on ebay, but it came without nuts/bolts/cup/wiring.
As for the wiring, supposedly as easy as tapping into +,- and the negative side signal going to the coil
As for your steering - first thing to check is air pressures, are they within spec? Those tires sometimes seems to seep out some pressure...
02 Bonneville - 904 wiseco/813 cams/FCR carbs/Dominator touring, ARK,AI,.Pieman igniter. Thruxton seat, superbars raised 1". Intiminators/Öhlins PL36 shocks, renntec rack.. Tourance tires , D9 bracketry
ivar is offline   Reply With Quote
Old 06-26-2009, 09:18 AM   #3 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
Speedo light
Use one WLEDx5 and one 74xHP3 bulb from SuperbrightLEDs for maximum brightness.
http://www.superbrightleds.com/mini-wedge.html
The tachometer would use two WLEDx5.
D9's brackets are a straightforward install. He might have one for a single speedometer. E-mail him: davidnyne at yahoo dot com.
Marty
Old 06-26-2009, 09:57 AM   #4 (permalink)
Thanks for the Replies, and information.
Yes, I know the D9 is for dual gauges - I had planned on getting a tach, and the D9 at the same time. I had E-mailed david, and he sent me a complete set of installation instructions, to help prepare me.
David seems to be a great guy, and a magician with the metal & machinery. He's quite a credit to our brotherhood.:
Old 06-26-2009, 10:44 AM   #5 (permalink)
Favourite Bike: 1972 Triumph TR6R
psasak's Avatar
Other Motorcycle: 1968 BSA A65L Lightning
Extra Motorcycle: 2005 Triumph Bonneville
Wiring the tach to the harness is not a big deal at all. The wiring in the harness exists in all the bikes to connect the tach to, you just have to tap into it.
My member album has pictures and wiring diagrams that may help you. If you've done any wiring mods/repairs to anything in the past, this is a piece of cake.
2005 Bonneville: 18 tooth sprocket, 135 Mains, 40 Pilots, 1 shim/Thruxton needles, no AI, K&N filters, Emgo Slip-Ons.
My Photo Album
2005 Bonneville 1968 BSA A65L
1972 Triumph TR6R
psasak is offline   Reply With Quote
Old 06-26-2009, 10:52 AM   #6 (permalink)
ivar's Avatar
On the 02's the red wire from pin15 on the igniter isn't present.
Old 06-26-2009, 02:34 PM   #7 (permalink)
Favourite Bike: Bonneville 07, "Bonnie"
koifarm's Avatar
Other Motorcycle: Past rides, 66 bonneville
Extra Motorcycle: Past rides, 72 bonneville
Answer?
That annoying front end looseness was bothering me as well.
See my post in "What did you do to your twin today?" for advice on tightening the headstock bolt. Mine was definitely not tightened to torque specifications, gotta blame the guy who set it up.
Takes a huge spanner but if you have a large crescent wrench you can do the job. Tightened mine a full quarter turn and a bit more.
Did make a difference but I'm still installing a steering damper ,one from Mike at Bella Corse (selmotion)
Try the tightening if that's not enough, go for a damper.
Sitting on a cornflake waiting for the van to come!
koifarm is offline   Reply With Quote
A few questions from a newbie JEFFW Twins Technical Talk 9 02-18-2008 02:59 PM
A Few Newbie Questions shoe The Rocket Science Forum 12 10-05-2006 10:50 PM
More Newbie Questions Scouser Twins Technical Talk 3 08-12-2006 07:35 PM
newbie with some questions grunt11b40x Speed Triple Forum 8 10-31-2005 11:31 PM
Newbie questions Spooner Hinckley Classic Triples 11 09-29-2005 01:54 PM
