Yes, that's basically it. You didn't mention what bike you're talking about, so I'll go with the book I have on hand. The Triumph Scrambler is supposed to have .98" to 1.37" of vertical movement.
To adjust, loosen the axle nut and then turn the adjusters and equal amount to get the proper amount of slack in the chain. If you are trying to loosen the chain (increase the movement), you will probably have to bump the wheel forward after you loosen the adjusters as it doesn't normally slide forward on it's own.
Check the alignment markings on the adjusters to make sure they are both in the same position relative to the frame. This is usually, but not always completely, accurate. It is important that the chain tracks properly on the sprocket, in other words, the sprocket should run in the center of the chain. With the bike on the center stand, spin the rear wheel and let it stop on it's own. If the sprocket is off center in the chain, then tweak with one adjuster slightly to change the angle of the wheel and try again. Repeat until the chain runs true on the sprocket. Recheck the slack and if correct, tighten the axle nut. It should be torqued to 63lb/ft on the Scrambler. Recheck slack and trueness as things can change when you tighten the axle.
By the way, I learned the "center sprocket in chain" thing from a life long motorcycle mechanic. He was also my dad.
Fast is fine, but accuracy is everything.--Wyatt Earp
Triumphs-'06 Scrambler, '07 Tiger 1050, '11 Tiger 800
'08 Moto Guzzi Norge
'74 Yamaha DT360A
