scrambler speedometer cable cure - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsOntario Tourism
Old 05-21-2009, 10:25 PM   #1 (permalink)
Does anybody out think or know the best cure for a squealing speedo cable ? I was going to just shoot cable lube in there but, if somebody has a better idea I'm open to suggestions.
Varna2Win is offline   Reply With Quote
Old 05-22-2009, 12:13 AM   #2 (permalink)
Favourite Bike: '06 Scrambler/'07 BonnieB
cdubya's Avatar
Other Motorcycle: '05 Yamaha WR 250
Extra Motorcycle: '05 Tiger
I pull the cable out of the housing from the bottom attach point at the hub, wipe it clean with WD40 and a rag, re-coat with a thin layer of bearing grease and put 'er back together. Haven't ever experienced the squeal.
'06 Scrambler: De-AI'ed, De-Snorked, K&N, Dual entry airbox mod, TORS, 135mains, 40pilots, thrux needles, no shims
'07 Bonnie Blk: De-AI'ed, De-Snorked, K&N + NH Peashooters, 118mains, 40 pilots, one shim
'05 Tiger 955i: Pulled airbox plate
cdubya is offline   Reply With Quote
Old 05-22-2009, 10:01 AM   #3 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
Speedo cable lube
I do exactly the same, once a year, no problem after four seasons.
Marty
Old 05-22-2009, 12:20 PM   #4 (permalink)
Thanks for the replies I'll do just that.
Did I get the right speedometer cable? Kittlemeier Hinckley Classic Triples 19 05-12-2010 11:46 AM
Speedometer Cable Noise DrewDesign007 Twins Technical Talk 11 01-26-2008 06:08 PM
Speedometer Cable TBS '98 Niall Hinckley Classic Triples 1 04-02-2007 09:52 AM
Speedometer cable broken. Need some help. anthonymelendez Twins Technical Talk 15 07-31-2006 11:15 AM
speedometer cable broke Speed Triple Forum 7 01-20-2005 11:36 PM
