Seat Height Discrepancy - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-18-2009, 07:36 PM   #1 (permalink)
Favourite Bike: My FXDCI - Del
As some of you may or may not know, I'm in the process of selling my beloved, but somewhat unwieldy Dyna and eventually (I won't bore you with the tacky whys and wherefores) replace with something a bit lighter and more flickable. So far a 2009 Bonnie is top of the list having testridden and been mightily impressed by it's smoothness and eager throttle response. There's still one other bike in the running which is the Buell XB12Scg with the cg standing for 'lower' basically. Buell advertise this machine's seat height as 726mm which is 25mm lower than the Bonnie's 751mm or roughly an inch in old money. With me so far? OK
Well I went to the local HD/Buell dealer, and when I could finally gain his attention, the sales guy very kindly allowed me to sit on a XB12scg machine even tho' this particular example was sold. Now I was wearing totally flat soled trainers which probably lose nearly an inch in comparison to my normal bike boots, but it felt much higher than the Bonnie even given this. Further, I struggled to reach the sidestand lug. Now I'm short ok, but I would expect to be able to tippy toe at least both sides on a bike with a seat height of 726mm, a very slim bike too, not one of your fat old HDs. In fact once I was on it, it felt very light and easy to manage despite the elevated to me perch. The sales guy, did advise me that the sidestand issue was easily solvable by simply reversing the lug on it to stick out a bit more. Fine, but the question is 'How is this possible? when I can easily manage a bike with a seat height ostensibly an inch higher than the Buell's and also do manufacturers also lie about seat heights as they do about other statistics? Perhaps Buell test their bikes with a 400lb gorilla aboard, and the suspension on it's softest setting I don't know. Anyone got any ideas???
Anyway, I'm hopefully giving their next bike in a short test run which will confirm or deny whether it will stand against the Bonnie.
Thanks
Andy
AndyB is offline   Reply With Quote
Old 05-18-2009, 09:28 PM   #2 (permalink)
Favourite Bike: Triumph Bonneville
Extra Motorcycle: Honda 750 (Mrs. BikerEm)
AndyB: Which Bonneville are you comparing the Buell XB12Scg with? You may be aware but in case not, don't forget that the T100 is the tallest of the current 2009 Bonnevilles.
Also how is the suspension set up? My Kawasaki, is quite a bit taller on the next to highest setting that I use for riding two up with my wife.
I've never knowingly seen a Buell XB12Scg but don't forget that a different apparent height may be due to the width of the bike. The Bonneville has relatively narrow seat which helps. I can get the balls of my feet on the ground sitting on my T100 and simply love the bike.
Bonneville T100, Goodwood green, center stand, grab rail, K+Q seat, city bags, Dart flyscreen, new shape tank but not FI :-(
BikerEm is offline   Reply With Quote
Old 05-18-2009, 11:13 PM   #3 (permalink)
Favourite Bike: 08 Speed Triple
wabill's Avatar
Other Motorcycle: 2010 Bonneville
Extra Motorcycle: 2010 FJR 1300
Forget the Buell and go with a Speed Triple. You'll not regret it.
DON'T WORRY, BE HAPPY!
wabill is offline   Reply With Quote
Old 05-19-2009, 05:31 PM   #4 (permalink)
Favourite Bike: T100
lewilewi's Avatar
Other Motorcycle: Fazer
Hi andy
May be a case that this Buell is set up differently to default factory settings ? Also I'am guessing you know that the new 09 se is a full 25mm lower than a T100 / 08 bonne.
Cheers lewi
lewilewi is online now   Reply With Quote
Old 05-19-2009, 06:48 PM   #5 (permalink)
Originally Posted by lewilewi View Post
Hi andy
Cheers lewi
Thanks Lewi. That may well be the case. I'll see what it is set up for when I throw a leg over it.
Old 05-19-2009, 11:53 PM   #6 (permalink)
wabill's Avatar
AndyB
Here's a link to a almost decent discussion of Buells.. It's not focused on seat height but I hope you find it a helpful read. These guys are in my neck of the woods.
http://pnwriders.com/general-discuss...-question.html
Old 05-20-2009, 12:16 AM   #7 (permalink)
Favourite Bike: Bonnies
Other Motorcycle: TT600
shock setting?
Thanks
Andy
Andy
The T100 has an adjustment on the shocks. It is possible the setting at the showroom may have been on the middle setting and the lowest setting will help. Adjustment is quick and easy and from highest to lowest makes a fair difference in bike height, but it may not make enough difference for you. I will tell you at 6'4'', I got the bonnie because the upright ride style seems to fit taller folks.
Bill20850 is offline   Reply With Quote
Old 05-20-2009, 03:29 PM   #8 (permalink)
Favourite Bike: 2008 Thruxton
Jeffs900s's Avatar
Andy,
Buell publishes "laden" seat heights. That is, with the Buell the published seat height factors in the suspension sag from a rider. I think they spec. a 160 lb rider. So the real-world seat height is higher than the published number would make it seem.
I loved my Buell. One of the few bikes that I wish I could "un-sell".
Good luck.
2008 Thruxton
Last edited by Jeffs900s; 05-21-2009 at 11:14 AM. Reason: I duznt spell two guud - typo
Jeffs900s is offline   Reply With Quote
Seat height on contemporary seat moyerjj Twins Technical Talk 1 04-13-2009 06:15 PM
Seat height on the S3 Bundyon_Jen Speed Triple Forum 26 04-14-2007 02:48 AM
Seat Height. Link06 Daytona Deliberations 4 02-10-2007 08:03 PM
seat height darmahman Twins Technical Talk 1 10-03-2006 12:12 AM
Seat height suemchenry Hinckley Classic Triples 5 09-19-2005 02:02 PM
