Bar End Mirror (A9638020) don't fit on 09 Thruxton
To anyone that might come across in replacing the broken bar end mirror on a 09 Thruxton, Part number A9638020 - Bar End Mirror do not fit on 09 Thruxton. That part would only fit on any previous Thruxtons. I found that out when my order came in today in replacing my broken 09 bar end mirror.
And here's the differences I found between the 08 bar-end mirror and 09 bar end mirror
- the adapter on the 09 is bigger in overall diameter than the OEM 09
- the adapter on the 09 is much longer because there's a end plug welded at the end of it, as a result, the capscrew that tighten it to the handlebar is waaaaay longer.
- The M8 x 35mm screw, spring, M5 x 35mm capscrew is way bigger on the 09
- The 09 mirror is slightly bigger than the 08.
I'll post up some pictures later, so you folks can see the differences.
