Originally Posted by Dunamis
Hey Frank, 80bhp and 61nm is impressive. Can you share what you did and/or post your Tune? I have an America not a Bonnie but your tactics should translate between the two bikes. I realise I can't use your tune but I can look at in detail in Tuneboy and see what works for me.
My 09 Bonnie Has the 904 TPUSA kit with the 11 1/2 to 1 HCPistons, 813 cams, and I opened up my Throttle Bodies to 38.5 CM.
The Airbox is removed and running Pod filters. The O2 sensors are removed along with the AI and I have Dominataor HT pipes.
I had the PCIII prior to the Tuneboy remap. So far just a good, clean AF map that I richened on the low end to stop some popping on decel. We just fed her fuel till she said she was full. We also moved the timing a bit in a flat spot.
Going back to the dyno tomorrow to see if there is any more to be had with the timimg and possible AF tweaks after the ign timing moves.My problem is I'm about computer ignorant but know what I'm tring to achieve. I'm lucky to have a riding buddy that reall knows commputers and is good with the tuneedit part of Tuneboy.
I've got a lot of dyno time and a list of the tunes we did working up to the present.
After I opened up my TB's, she really went lean, so my tune would probably be way rich for a stk TB set up. I can't post it , but if you look ion my photo album, you'll see the ign timing as it is now.
Later
