Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Old 07-19-2008   #1 (permalink)
Favorite Bike: Trophy 1200
Talking Clock
Howdy, I have been having a problem with my Trophy's clock. I uncover it....er her, in the morning just to see that the clock stopped some time during the night. Maybe 1100, sometimes 0100, but nothing consistent. Later in the initial ride to work she starts working. The night temp ranges from 48-59 degrees. Could it be the cold, or does she hate me?
Also if someone could please tell me what the knob in the left fairing storage is for I might get a full night sleep. It's right above the fuses. I have a 1996. Thanks.
"Always ride faster than the Angle of Death can fly".
SpongeBobTrophyPants is offline   Reply With Quote
Old 07-19-2008   #2 (permalink)
Favorite Bike: Triumph Trophy 1200
medic274's Avatar
Other Motorcycle: Kawasaki Vulcan
I was having a similar issue with my clock. I really didn't think anything of it, thought it was just one of those glitches, and actually thought it was beneficial, because the clock would not wear down the battery if the bike sat for a longer time. I had put a brand new battery in, so I was pretty sure it was not caused by a low voltage situation. However, after I did some service to the bike, and ended up taking all the fairings off, and had disconnected the electrical harness, after I put it back together, the clock has been running continuously, and actually keeping fairly accurate time. So, perhaps you might want to try simply disconnecting the wiring harness under the front right side of the fairing, and lubing it with some dielectric grease before you reconnect it.
The knob inside the RIGHT side fairing storage compartment, above the fuse box, is to adjust the headlight up or down.
medic274 is offline   Reply With Quote
Old 07-19-2008   #3 (permalink)
Other Motorcycle: 1st bike, CB350
Extra Motorcycle: You have one?
Clock & Knob
The knob is for adjusting the headlight between fully loaded bags and passenger and one-up riding.
The clock is sometimes a grounding issue or a low voltage thershold for operation.
That's all I know.
[SIGPIC]Leftlane Rider (AKA OLDKID)
You're only young once, but you can be immature forever.
Leftlane_Rider is offline   Reply With Quote
Old 07-20-2008   #4 (permalink)
andrewb's Avatar
Other Motorcycle: Daytona 1200
Had that problem with my '96 Trophy's clock. First I tried a new ground strap, didn't help. Then I gently snugged up the nuts on the back of the clock....That did it, never dropped a minute since.
andrewb is offline   Reply With Quote
Old 07-21-2008   #5 (permalink)
Other Motorcycle: 1995 Yamaha 1100 Virago
Same issue with my 2000. It will be off when I get out in the AM. I can set it on the way to work or as I am riding and it will keep perfect time all day. Have not meesed with any wiring on it yet. I don't usually care what time it is while I am riding.
BlueTrophy is offline   Reply With Quote
Old 07-22-2008   #6 (permalink)
Thanks gentlemen I appreciate the replies. This forum is better than talking with the Triumph dealer. When I have her serviced I will check the wires and put some of that goo on them. By the way I think you do get more chicks with the maroon ones.
Old 07-23-2008   #7 (permalink)
Favorite Bike: 2001 Trophy 1200
Other Motorcycle: 2006 Scrambler
Don't want to burst your bubble,man,but quality chicks go for Platinum over Maroon 10 to 1.
Those who danced,were thought to be quite insane by those who couldn't hear the music.
WildBill is offline   Reply With Quote
Old 07-23-2008   #8 (permalink)
Maroon shroon and Platinum is just silver, but... Pacific Blue, now thats a color!
Old 07-23-2008   #9 (permalink)
andrewb's Avatar
Define quality
Old 07-23-2008   #10 (permalink)
medic274's Avatar
BRG, the only color they should have offered.
Formotion clock? ChardT100 Twins Technical Talk 15 07-25-2007 06:34 PM
Setting the Clock on 06 jrbarney Sprint Forum 4 05-23-2007 07:49 PM
reset clock flatspins Daytona Deliberations 3 11-29-2005 08:01 AM
10k on the clock! Scottius Sprint Forum 2 09-27-2005 05:07 PM
CLOCK Sprint Forum 2 04-07-2005 12:09 PM
