I use the bike for work each mon-fri the battery is flat by the end of the week even if I do along run of 50miles took the bike back to the shop who said the charging system was fine? ,they put a switch on the lighting circuit so that I could isolate when the parking light .still no change
Check the wiring plug that connects the alternator lead to the wiring loom. I had a similar problem and found that the spade terminals inside the connector had corroded and got hot, causing the plug to partly melt. Charge not getting to battery!
Cut off damaged plug and replace with push fit terminals, problem solved.
Fixit
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
