Most DOT 3 brake fluid also meets DOT 4 spec. it should say so on the can. I use Castrol LMA and it works fine.
The big allen wrench in your tool kit is for the chain adjuster. If you don't have your tool kit I would measure across the flats in the adjustment and go to Sears or NAPA, they should be able to fix you up.
