JardineProducts.comCommonwealth MotorcyclesTriumph DetroitMotorcycle.com Classifieds!TriumphPerformanceUSAMotorcycle.comTrident-Exhausts.com
Allstate
British Motorcycle Gear
Old 05-16-2008   #1 (permalink)
Newbie
Favourite Bike: Yamaha XS1100
Other Motorcycle: Triumph Trophy
Unhappy Air Box nuts and bolts HELP
I have just unscrewed one of the two bolts on the right side of the air box that hold it together. Reason to attach a small bracket. Now the problem is i heard a nut fall in the air box. Question is how do i remove it. Or do i leave it there. The way i see it is from the bottom of the carb to the bottom of the air box is quite a large drop so should be safe. What do you guys think. Triumph Trophy 900
Tony
solo1 is offline   Reply With Quote
Old 05-16-2008   #2 (permalink)
Favourite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
Well, you have to pull the carbs to get the air box off. The nut you heard fall is probably the brass nut that the screw go's into. It's probably between the filter and the carbs. I don't know about you, but I think I would pull the box and open it up and get it out. A good bump could bounce it up into a carb.
My 3 cents worth.
Erv
Deep in the Heart of Texas!!
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 05-16-2008   #3 (permalink)
Favourite Bike: 99 Trophy 1200
Mark62's Avatar
Other Motorcycle: 82 Honda CM 450
Extra Motorcycle: 80 Honda Express 49cc
I agree with ERV...sorry.
Mark
Your only hope is to try and fish it out were the breather hose connects.
Mark62 is offline   Reply With Quote
Old 05-22-2008   #4 (permalink)
Favourite Bike: Trophy 900
Hi Tony
just a thought you said the bolts were on the side of the air box, is this the two bolts under the side panel on the mid section of the air inlet boxes and not the screws on the air filter box itself.
if so one bolt goes itno the battery box I think and the other just in front and both nuts are behind the tubes not inside them. Ill check my bike tommorow
griff
griffsalt is offline   Reply With Quote
Old 05-29-2008   #5 (permalink)
Mark62's Avatar
Solo
Did you get it?
Need bolts...no, not nuts FelixLeiter Speed Triple Forum 2 05-24-2007 01:05 AM
Captive nuts for seat bolts- 06 ST GABLERCIGARS Sprint Forum 14 12-10-2005 01:29 PM
Chrome metric nuts and bolts in L.A. area? dazco Twins Talk 16 11-23-2005 05:18 PM
Little rant ... sizes of bolts, nuts, etc? SaddleTramp Sprint Forum 9 09-28-2005 12:24 PM
Progressive shocks, bolts and nuts. Tadpole The Rocket Science Forum 6 07-26-2005 05:34 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
