Motorcycle.com
Old 05-16-2008   #1 (permalink)
varta batteries
are these any good and is this the right one for my 1200
http://www.watchbattery.co.uk/shop/p...12014010.shtml
millwallfcuk is offline   Reply With Quote
Old 05-16-2008   #2 (permalink)
Favorite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
If it's a 2000 up, yes. If it's a 1999 down, check the dimensions first. It will fit if the dimensions are the same.
Erv
Deep in the Heart of Texas!!
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 05-16-2008   #3 (permalink)
thanks erv
mines a 2002
i'm after a really good battery, the last only didn't last a year - not sure why?
i only use the bike now and again in the summer other than a 3 week euro trip and for this i plug chargers and all sorts into a 12v socket so need something good...
is this what i'm looking for.
Old 05-16-2008   #4 (permalink)
ervdrvr1's Avatar
Yep, should be fine. Varta batteries are made by Johnson Controls, same as my WallyWorld EverStart batt. It's an AGM(absorbed glass mat)batt that works great in motorcycles. It comes dry with a pre measured container of acid mix. Dump the acid in(don't worry about it not being full to the top, it's not supposed to be) and put the seal on and charge and good to go. Mine has lasted for about 3.5 years so far. For long periods of not riding(1 to 2 weeks), I disconnect the neg lead on the batt to keep the clock from running it down. I hook up a batterie tender for extended storage over 2 weeks.
Hope this helps.
Erv
Old 05-17-2008   #5 (permalink)
thanks erv - i'll get one ordered.
Old 05-17-2008   #6 (permalink)
me again!
just something you mentioned around disconnecting the battery to charge as the clock drains power.... would this explain my batterys death even when on the optimate?
james
Old 05-17-2008   #7 (permalink)
ervdrvr1's Avatar
James,
Not sure 'bout that. Just a habbit of mine now. I only use the battery tender for extended un-use. I just disconnect the battery when I know I'm not going to ride for a week or two. My original battery was a regular wet type. I kept the battery connected all the time and hooked up to the tender whenever I wasn't riding and it only lasted a couple of years. I think the design of the AGM plus only using the tender for extended periods of un-use is helping get longer life out of it.
Erv
Old 05-17-2008   #8 (permalink)
Favorite Bike: '98 Sprint Executive
Other Motorcycle: '01 Suzuki DRZ400
Extra Motorcycle: '70 Norton Commando 750
Erv, you implied that the Everstart battery is AGM, I'm just confirming that. I'll check to see that they have my size the next time I'm in there. I'd much rather have AGM than wet plates.
This is a post in the workshop talk forum. It's an interesting read. I haven't investigated it, my system charges at 14.5+ volts most of the time per the on board volt meter.
http://www.triumphrat.net/modificati...-solution.html
I solved any clock drain problem. I took it out to install the Whistler motorcycle radar detector display. I now tell time on the bicycle computer installed on the left handle bar. It's a poor man's GPS, tells miles, avg. speed, top speed, time ridden, and the BEST, the MPH is accurate!
sailfish is offline   Reply With Quote
Old 05-17-2008   #9 (permalink)
ervdrvr1's Avatar
Sailfish,
Not ALL EverStart's are AGM. They do have the wet plates as well. I think your stock battery is a YB14L-A2 wet plate(5 1/4l X 3 1/2w X 6 9/16h), the AGM I think is ETX15L. Double check though to be sure the size is the same and the posts are the same and on the same side. Also, make sure it's a 14 amphour rating. For 2000 up Trophy's it's ES14BS(5 7/8l X 3 1/2w X 5 3/4h).
That is an interesting read on the charging system. I know mine charges a little low at 1000rpm idle, so I turned mine up to appx 1100-1200rpm. A little better, but I think I might investigate further.
Hope this helps.
Erv
Deep in the Heart of Texas.
Old 05-20-2008   #10 (permalink)
If you have to add acid, then it's not an AGM battery. AGM's have no caps, never need refilling, you couldn't add any if you wanted to. They also are good to go right out of the box, no charging needed. I have had one in my Vulcan 750 for 2 years now. No conditioning needed, so I didn't keep it on trickle charger during the winter at all. They also say if you do keep them on a float charger, it needs to be one of the new "smart" chargers." They cost a bit more, about $80 vs. $40 for cheapo wet batt. I had a problem with the first one I had, overcranked it while trying to start the bike first time of the Spring, and melted the ground post... I took it in with me for core return when I went to buy a new one, they told me there's a 1 year free replacement, so got a brand new one for $0... not bad. That alone was worth the extra cost. BTW, I forget the brand, but bought it at Advance Auto. I know none of the local ADAP's or AutoZone's had any in stock, and I would expect to pay 50% more at a bike specific shop...
medic274 is offline   Reply With Quote
Odyssey batteries? Fyr Twins Technical Talk 2 11-30-2007 03:40 PM
Varley red top batteries. Tigerfeet Tiger Workshop 0 02-04-2006 09:41 AM
batteries & winter Longshot92 Modifications & Workshop Talk 19 01-02-2006 12:39 PM
Odyssey batteries matdav Sprint Forum 0 07-13-2004 12:08 AM
Batteries? Timtiger Tiger Chat 6 06-22-2004 06:53 PM
