Motorcycle.com
Old 05-14-2008   #1 (permalink)
Question fixing my pannier
you may remember during the winter i took the 1200 out for a run to keep it alive and i forgot to hitch the pannier on properly resulting in it bouncing down the road after a speed bump.....
anyway, lots of scratches but no massive damage other than the hook at the bottom for the latch was bent.... i've cut of the bolts today and straightened the piece of metel but i don't know what tool to re-fix it....
i have a rivet tool but that only pulls one side and the other seem to be attached differnetly.... anyone got any ideas?
here a pic....
millwallfcuk is offline   Reply With Quote
Old 05-17-2008   #2 (permalink)
anyone got any ideas before i go get robbed by my friendly local triumph garage?
Old 05-17-2008   #3 (permalink)
Favorite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
James,
They where originaly pop-riveted on whith a washer on the inside of the box for the one rivet on the end. I would think pop-rivets would be fine to put it back together. Just make sure you use the rivets with the steel pull post and not aluminum and it should be fine. Put the rivets in the same direction as your other side box and you shouldn't have any clearance probs with the latch.
Erv
Deep in the Heart of Texas!!
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 05-17-2008   #4 (permalink)
Favorite Bike: '98 Sprint Executive
Other Motorcycle: '01 Suzuki DRZ400
Extra Motorcycle: '70 Norton Commando 750
I did that job several years ago, pop rivets are fine. I put them in from the side opposite the hook.
sailfish is offline   Reply With Quote
Old 05-17-2008   #5 (permalink)
I did the same. My cases also were vibrating over rough roads. Some of the fuzzy sided velcro(self-sticking) on the inside of the hook really tightened up the locking mechanisms. Quiet as a mouse.
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 05-19-2008   #6 (permalink)
good tip mate - cheers
Old 05-26-2008   #7 (permalink)
pannier fixed and back on today ready for touring so thanks guys for the help.
james
fixing odemeter fattony23 Twins Technical Talk 7 07-28-2007 02:22 PM
speed four belly pan fixing chelasaurus Modifications & Workshop Talk 0 06-20-2007 02:50 PM
Fixing dented tank? tri650 Modifications & Workshop Talk 19 03-23-2007 03:56 AM
Front End Fixing Kit mtnwinds The Rocket Science Forum 10 12-02-2005 07:38 PM
