Motorcycle.com
Old 05-12-2008   #1 (permalink)
Favorite Bike: The one I'm riding
fundyrider's Avatar
Fuel leak
The last couple of weeks, my 1200 Trophy has been starting harder than usual, sometimes I get a faint smell of gas, at times it seems to be starving for fuel at low revs, today I went into a store for about 10 min and when I returned to the bike there was fuel leaking down the side of the bike and a pretty good puddle under it. I got it home and parked it in the garage and not a drop has leaked since. Any idea whats going on?
Peter
"You gotta make the journey out and in" Mike Pinder
fundyrider is offline   Reply With Quote
Old 05-12-2008   #2 (permalink)
Mark62's Avatar
Can you be more specific about"fuel running down side of bike". It sounds like a float is hanging in a carb or your petcock is leaking.
Mark
Mark62 is offline   Reply With Quote
Old 05-13-2008   #3 (permalink)
fundyrider's Avatar
fuel looked to be coming from the air box, dripping on the rubber boot on the alternator terminal, bike was on the side stand.
Old 05-13-2008   #4 (permalink)
Newbie
Favorite Bike: Not Sure
Other Motorcycle: 1995 Sprint
Extra Motorcycle: CBR 600
Its the Float
I think Mark62 is right. I have the same problem with a 1995 Sprint 900 I just bought. The previous owner managed to only put 8000 miles on it in 13 years. I am on my third tank of carb cleaner with positive results. With each tank the low end performance improves and after the first tank the leak stopped and has not returned. Its probably one of the floats, I suggest working the throttle hard and carb cleaner.
Mark Anderson is offline   Reply With Quote
Old 05-13-2008   #5 (permalink)
Favorite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
I'd say a float sticking, but, check your fuel lines for any splits just in case.
Erv
Deep in the Heart of Texas!!
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 05-13-2008   #6 (permalink)
Check the oil for gasoline! Shouldn't be contaminated but why risk it!
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 05-13-2008   #7 (permalink)
Other Motorcycle: 1995 Yamaha 1100 Virago
Do check the oil. My nephew asked me to check out the leak on his Yamaha and I found the crankcase full of gasoline from stuck floats. Removed the carbs(as in most cases with newer engines, whoever designed them has never had to work on them) and cleaned them well and put them back in. Drained the oil and left the crankcase open for 24 hours. All is well.
BlueTrophy is offline   Reply With Quote
Old 05-13-2008   #8 (permalink)
Favorite Bike: '98 Sprint Executive
Other Motorcycle: '01 Suzuki DRZ400
Extra Motorcycle: '70 Norton Commando 750
If the bike has Mikunis then the float seats need to be inspected and most likely replaced. If the seat is cracked, no amount of fuel system cleaner will fix that. Search the forum and you'll find plenty to read on the topic.
sailfish is offline   Reply With Quote
Old 05-13-2008   #9 (permalink)
fundyrider's Avatar
Thanks for all the replys, most likely carbs need cleaning, never worked on carbs before, not sure it's a job I want to tackle myself.
Can't say I smell any gas odor coming from the crankcase although my oil level appears to be higher in the sight glass than I normally keep it.
The bikes previous owner was a cruise ship captain, so the bike sat for months at a time, judging by other issues I've discovered since taking ownership, mostly lack of maintenance, I doubt he used gas treatment before laying the bike up.
I'll study the service manual for a bit to get an idea how hard doing the carbs are
Old 05-13-2008   #10 (permalink)
Other Motorcycle: 83 GR650 Suzuki
Fuel leak
Having just gone through exactly what you are describing I would recommend purchasing new float assemblies. I chose to replace the dried out o-ring seals on the floats and I reset float heights but after reassembling everything I ran the bike and the #2 carb flooded the airbox and crankcase with fuel again. The needle looked ok but it was not seating as required.
My new floats came today but now I am out another 4 litres of synthetic oil, a filter and about 3 weeks of riding time!
While I had everything apart I also changed all my fuel and vacuum lines.
Hope this helps.
mcg63
mcG63 is offline   Reply With Quote
Fuel leak mcG63 Trophy 2 01-05-2008 01:58 AM
Fuel leak humbug Daytona Deliberations 10 08-18-2006 12:57 PM
fuel leak.... help! prez1374 Triumph SuperSports 9 04-13-2006 10:22 AM
Fuel Fitting O-Ring's / Fuel Leak BooneDog Speed Triple Forum 0 01-02-2006 06:34 AM
fuel leak bigbird T3 Sport / Touring Forum 9 04-05-2005 04:36 PM
