LED's are great
I installed a fuse block on my T-100 and connected LED running lights to it. The principle is the same on all bikes.
To replace front and rear turn signal bulbs with LED's either by an LED replacement bulb with a built in compensator for the reduced power requirement or add one to each bulb wire.
The running lights I installed are very bright and use minute amperage. I am waiting for bulb replacement prices to come down a bit because I want the built in compensator.
Om mani padme hum doo lang doo lang shooby dooby Karma down dooby down. Let us dance to the music of compassion.
