AdvanstarMotorcycleShowsMotorcycle.comBikeBandit
ShopTriumph.com
Old 04-13-2008   #1 (permalink)
LED lighting ?
Has anyone converted their bulbs over to LED? I am considering doing so , as I understand they draw a lot less amperage. This said the obvious would lighten the load on the alt. I this a correct thought?
Coupled to this train of though... I am also considering adding a set of driving light to the bike. What are the experiences with this? HID systems?
Thanks for any and all input!
Gr8lite is offline   Reply With Quote
Old 04-13-2008   #2 (permalink)
LED's are great
I installed a fuse block on my T-100 and connected LED running lights to it. The principle is the same on all bikes.
To replace front and rear turn signal bulbs with LED's either by an LED replacement bulb with a built in compensator for the reduced power requirement or add one to each bulb wire.
The running lights I installed are very bright and use minute amperage. I am waiting for bulb replacement prices to come down a bit because I want the built in compensator.
Om mani padme hum doo lang doo lang shooby dooby Karma down dooby down. Let us dance to the music of compassion.
Flyingscott is offline   Reply With Quote
LED Instrument lighting chefjpd Daytona Deliberations 2 01-10-2008 07:43 AM
gsxr footrest and LED license plate LED brake light installed MotoRaider Speed Triple Forum 19 01-23-2007 09:13 PM
speedometer lighting bonnienewbie Twins Technical Talk 2 01-10-2007 04:55 PM
need better lighting H.I.D evand Twins Technical Talk 10 08-03-2006 12:30 PM
Lighting RandyDTFR Triumph SuperSports 23 12-23-2004 12:18 PM
