Old 04-11-2008   #1 (permalink)
Trophy1298's Avatar
Brake light trouble
The lights do not get brighter when I apply the brakes. Well, they get a little brighter but the elements for the actual brake lights do not light up. Changed the bulbs, changed the brake switch (on the front lever) but still no fix. Not a problem I've had b4. Anyone have a fix?
Thanks
Brian
Trophy1298 is offline   Reply With Quote
Old 04-12-2008   #2 (permalink)
Favorite Bike: 97 "speed trophy"
does your horn work? the horn shares the same fuse for the brake light. also did you check both brake pedals, foot and hand to see if they work.if all ok check power to the green wire going to the brake lamp. if power there has to be bulb or connection at bulb.
k_dencuz is offline   Reply With Quote
Old 04-13-2008   #3 (permalink)
Trophy1298's Avatar
Horn works and same brake light result no matter front or rear brake. I'll have to pull it apart next weekend and see waht is going on.
Thanks,
Brian
Old 04-13-2008   #4 (permalink)
Favorite Bike: 2002 Trophy1200
Doublenikkel's Avatar
focus the light
I added some reflective tape around the inside of my taillight lense and cut two small diamond shapes in the lower section for the light to go thru to the license plate.Worked well as it kept the light from escaping around the lense,now it only goes out the back .Plus I added some of those blinking hyper light pods just under the lense to supplement the "noticability" of the brake lights!!!!
It`s better to put a knee down, than your head!
Doublenikkel is offline   Reply With Quote
Old 04-14-2008   #5 (permalink)
Mark62's Avatar
Be sure to check the "ground" , there might me corrosion at the grounding lug. Also check for broken or crushed wiring.
Mark
Mark62 is offline   Reply With Quote
Old 04-15-2008   #6 (permalink)
Oh yea!
Come to think of it,I had an issue like this last year.I would apply the brakes(front or back) and no brake lights.Taillight was on but no brake light. Well after adding the Hyperlight PODS.I still had the same issue,but my PODS were blinking(as they should),so I knew I was getting power at the bulbs.then it hit me!! I had put in higher wattage Halogen bulbs,I switched back to the standard wattage and just like that, started to work all the time!! The stock wattage is 5/21,I had 15/50 in there.
Now I never blew a fuse,but perhaps the higher wattage was causing an issue in some form?
Old 04-19-2008   #7 (permalink)
Trophy1298's Avatar
Thanks for all the input. It has been too pretty to work on the Trophy. The riding weather is not this good for long here so I have been taking advantage of it.
I'm planning to get to it tomorrow afternoon.
I appreciate all the brain storming.
Brake trouble, anybody else rebuilt the front brake Master cylinder uzidzit Twins Technical Talk 3 10-13-2007 12:55 AM
Anybody having trouble getting the brake fix done 24gt Speed Triple Forum 13 06-21-2007 03:50 PM
Speed Triple Tach/Trouble Light Wiring Help kuhlka Speed Triple Forum 6 10-29-2006 06:31 PM
Tail Light Trouble - Burnt Out ponycorn Twins Talk 4 07-05-2005 10:21 PM
Malfunction light trouble... weezer Speed Triple Forum 2 02-04-2005 09:58 PM
