Old 03-19-2008   #1 (permalink)
Favorite Bike: Trophy
Trophy with cb radio/antenna question
Does anyone here run one, and if so how did you mount the antenna? I just scrapped my first idea, got any ideas?
Brian Holland
'02 Trophy 1200
http://community.webshots.com/user/concoursbdh
moto2wheelin is offline   Reply With Quote
Old 03-20-2008   #2 (permalink)
Favorite Bike: 2000 Triumph Trophy 900
Brian, I don't have an antenna on my bike, but I have an idea. I was thinking about Harleys and how they have them mounted on the lid of their top-box. It takes up some space in the box though.
Scott
Ride, Eat, Sleep, Repeat.
trophyrider00 is offline   Reply With Quote
Old 03-20-2008   #3 (permalink)
Thumbs up CB radio
Brian....
I'm using a Cobra handheld CB/weather radio that I found through Sierra electronics about about 4 years ago, together with the helmet mounted mic and headset. The CB mounts on an adapter plate that fastens to the clutch reservoir on the left handlebar. There is a harness that enables you to use a Push To Talk (PTT) switch attached to the left handlebar via a velcro tab. For power, I installed an accessory outlet in the right fairing liner and use the bike's internal battery to power the radio. Using the "rubber duck" antenna mounted on the CB, I've probably got a mile or better range with it, very nice when riding with my wife on her Goldwing or with other friends. If you have any questions, post and I'll try to answer.
Frank
sunrider is offline   Reply With Quote
Old 03-20-2008   #4 (permalink)
Originally Posted by sunrider View Post
Brian....
Frank
Thanks for the info. I have run one of those type radio's for a few years myself. Finally upgraded a couple of years ago to the J&M 2003 cb radio. Very small and compact. Mounts neatly on left side of bars. The antenna was easy to put on my last bike, I just hate to throw off the lines of the Trophy with an antenna! I want it to be adjustable for running in close when not using the trunk and then clear it when it is mounted. Haven't got it figured out yet. Thanks.
Brian Holland
'02 Trophy 1200
Old 03-21-2008   #5 (permalink)
Favorite Bike: '01 Trophy 1200
Other Motorcycle: '84 GL-1200
Thru the Glass?
How about using one of those thru-the-glass antennas?
http://www.scannerworld.com/content/product/model/GM27
I'd consider mounting it in a lower corner of the windshield - it sure will eff-up the lines of the bike.
rgbeard is offline   Reply With Quote
Trophy Question roxythruxton Classic, Vintage & Veteran 4 09-29-2007 12:44 AM
which radio? mouse Sprint Forum 5 03-27-2007 10:22 AM
blues radio Nochicanes Biker Hang-Out 1 01-26-2007 01:32 PM
CB Radio on Sprint Paul-K Sprint Forum 10 09-11-2005 02:44 PM
XM Radio Options for Trophy YankeeCousin Trophy 3 04-25-2005 08:03 AM
