Motorcycle.com
Old 03-18-2008   #1 (permalink)
'Busa Calipers?
Its springtime in the Rockies and I'm getting the Trophy ready.
Since I'm going to replace the brake fluid anyway, I thought I
might try the Hayabusa caliper upgrade. Lots of people mention
it, but I have never found anyone that did the upgrade themselves.
Can anyone offer some first hand knowledge on the difficulty
of the upgrade? What additional parts are needed also? Do you use the stock
Trophy lines or Hayabusa lines? Any info will be greatly appreciated!!!
JD900 is offline   Reply With Quote
Old 03-18-2008   #2 (permalink)
MotT3's Avatar
Drain and unbolt your original calipers....using new copper washers on the banjos attach the Tokico 6 pots bleed and use.
The same calipers were used on ZX9r, ZRX, GSX1400, Some Bandits, GSXR1000 (the first one) etc etc.
You could of course also pump out and clean all the pistons, apply copper grease to the necassary parts etc etc
www.mottleybiker.com
MotT3 is offline   Reply With Quote
Old 03-18-2008   #3 (permalink)
Favorite Bike: '98 Sprint Executive
Other Motorcycle: '01 Suzuki DRZ400
Extra Motorcycle: '70 Norton Commando 750
Yep, it's that easy. R&R with new washers. The angle of the banjos on the caliper end of the Triumph lines are slightly tight for the 'busa calipers but the stock lines work fine, it's just different.
sailfish is offline   Reply With Quote
Old 03-19-2008   #4 (permalink)
Thanks for the info guys. It doesn't seem too complicated, so I might as well give it a try!
Old 03-19-2008   #5 (permalink)
mnmrosen's Avatar
I'm another one with the 6 pots. It's as easy as removing and installing the stockers.
1996 Triumph Trophy 900
2003 Kawasaki KLX400SR
mnmrosen is offline   Reply With Quote
Old 03-20-2008   #6 (permalink)
Favorite Bike: 99 Trophy 04 Speed Four
gundog's Avatar
Changing calipers was a great upgrade for my Trophy.
gundog is offline   Reply With Quote
Saw the naked Busa in person Shaunlee Speed Triple Forum 11 11-26-2007 09:44 AM
Busa calipers - need advice DarekF6C Sprint Forum 11 10-18-2007 04:33 PM
Busa and Gixxer 1000 VS. Rocket! Chi-TownRocket The Rocket Science Forum 11 07-25-2007 01:17 PM
Busa chaser oldmanjob Twins Technical Talk 20 07-03-2007 11:13 PM
Busa Caliper Transplant Green01SprintST Sprint Forum 13 06-30-2007 07:53 PM
