AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBanditMotorcycle.com
Old 04-21-2008   #11 (permalink)
Favorite Bike: '98 Sprint Executive
Other Motorcycle: '01 Suzuki DRZ400
Extra Motorcycle: '70 Norton Commando 750
Originally Posted by griffsalt View Post
any ideas how to remove a brake pad retaining pin from the rear caliper with a stripped allen key slot!!
My solution to that problem was to drill it out. I progressively drilled larger until there were essentially just threads left on the end of the pin. I was then able to turn it out with either an Easy Out or by forcing an old screwdriver in there. If you can find a left handed drill bit, it may turn out in the process of drilling. Anti-seeze (copper grease) on the new pins should cure the problem.
sailfish is offline   Reply With Quote
Old 04-22-2008   #12 (permalink)
Favorite Bike: MotT3's Speed Triple
Location: Sydney Australia, moving to Ipswich Queensland!
Other Motorcycle: Nude Sprint Sports
Extra Motorcycle: Maybe one day
Thats a toughy, the head is recessed. I would try an ezy out, the end of a larger size may just grip in the socket head of the screw.
Other than that, drill it out as sailfish suggested.
Good luck with it,
Cheers,
Roden
Roden is offline   Reply With Quote
T140 Head Gasket Woolly Classic, Vintage & Veteran 4 02-02-2008 02:47 PM
head gasket annealing firedog Classic, Vintage & Veteran 6 12-30-2006 10:30 AM
Head Gasket?? triumphrdr Speed Triple Forum 14 11-12-2005 08:41 PM
Head Gasket??? flick427 Twins Talk 8 08-02-2005 11:36 AM
head gasket Triumph, Models & Dealers 0 08-18-2004 12:23 AM
