Steve,
If it was running fine before you washed it, it's most likely NOT the crank sensor. Check the engine kill switch on the handlebar, you may have gotten water in it shorting it out. Also, check the clutch switch and the side stand switch for the same thing.
Erv
Deep in the Heart of Texas!!
"Life is tough, but it's tougher when your STUPID!" John Wayne
