Old 03-08-2008   #1 (permalink)
Favorite Bike: Triumph's
Symtec Heated grips
Any body installed symtec heated grips on your Trophy. Found a sprint and tiger owner that had and are happy. Wondering about wiring on the trophy. For the price will forego fixing what is on bike now and may install the symtec system. Thanks
Rusnsc is offline   Reply With Quote
Old 03-09-2008   #2 (permalink)
Favorite Bike: Trophy 1200
Symtec
Yes, I fitted the Symtec grip heaters. The hardest part is getting the grips off (and that's fairly easy). Wiring instructions are included and it's all straight forward stuff.I wired mine so that the live feed is taken from the wire that goes from the ignition switch to the lights. That way they will only operate when the ignition is switched on ( to avoid the dreaded flat battery ).Your bike wiring may, of course, be different.
I went for the plastic switch option, which is very small and difficult to operate with thick gloves. I imagine the toggle switch would be easier to use.
I have never needed to use the high setting; they have always been hot enough for me.
I decided that, for the money, they were worth taking a chance on and I'm glad I did.
Hope this has helped.
John.
relocatedfixer is offline   Reply With Quote
Old 03-09-2008   #3 (permalink)
Thanks John
Seems like it's an easy thing to do. I will remove whats on my bike and install the symtec. Thanks again
Heated Grips for TT / S4 craneG19 Triumph SuperSports 5 11-05-2007 11:27 PM
heated grips millwallfcuk Trophy 2 06-01-2007 05:44 AM
OE heated grips davsato Sprint Forum 3 04-03-2007 01:26 PM
heated grips? bonnienewbie Twins Technical Talk 5 12-27-2006 09:05 AM
Heated grips (again) Copper Twins Talk 8 11-02-2005 06:45 PM
