My wife's right grip was bad. wires were broke under the grip. I replaced that grip. If your wires have been broke at grip repace,if cut under fairing you might be able to fix.Not sure why someone would need to cut wires to disable it thought? I replaced her grip with factory because that is what was on it but I put aftermarket on my VTX for less than 1/3 factory cost and they work great!
