Progressive Insurance
britishcustomsMotorcycle.com Classifieds!Motorcycle.comCycleGear.comAdvanstarMotorcycleShowsBikeBanditTriumphPerformanceUSASpringfield ArmoryAnnitori DistributingSportbikeTrackGearAmericanMotorcyclistAssociation
CycleGear.com
Old 02-28-2008   #1 (permalink)
Favorite Bike: 97 "speed trophy"
gray and black
so i have been wondering, why are some engines gray and some black?is there a difference between the two? I have a trophy 900 gray!
k_dencuz is offline   Reply With Quote
Old 02-28-2008   #2 (permalink)
Favorite Bike: 07 Triumph Sprint ST ABS
F4sSprintST's Avatar
Other Motorcycle: 06 Suzuki 650 DR
The black ones are faster.
Got 6 Pots?
- Tokico 6 pot calipers & Gafler HH pads
- PowerBronze Shield & Pazzo levers
- Trident Exhaust, TOR & 18T front sprocket, speedo healer, 2k bars
- Skyking Frame & MV rear axle sliders, Clear Alternatives smoke tailight, 6k HIDS
F4sSprintST is offline   Reply With Quote
Old 02-28-2008   #3 (permalink)
Favorite Bike: Trophy 1200
Grey/Black
I replaced the grey engine in my 1998 1200 with a low mileage black one I bought from a breakers yard. I believe that the black engine is geared slightly higher in fifth and sixth gears, to help with fuel economy. There is also an oil level viewing window instead of a dip-stick and the oil filler is located on the right, instead of the left, as you sit on the bike.
The alternator was upgraded from 25amps to 40 amps. The alternators are engine specific and are not interchangeable ( see my previous posts ).
In my case the black engine is certainly faster than the grey one, but then that could be because the grey one is in bits. I will rebuild it one day, honest !
John.
relocatedfixer is offline   Reply With Quote
Old 02-28-2008   #4 (permalink)
I guess there must be a change in 98 because my 98 900 has a black engine.
My Photoalbum
Trophynorway is offline   Reply With Quote
Old 03-04-2008   #5 (permalink)
Favorite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
Black engines have an entirely different casting to make them a little lighter than the grey's. Most of the engine gaskets are different. As far as the internals(crank, rods, etc), not sure if the same or not. Black engine also has a beefier starter sprag unit to correct probs from the grey's. ALWAYS make sure you have the VIN#(or engine serial # if changed) with you if you order parts for the engine(or any parts for that matter). Changes are more VIN # specific than year specific. Horsepower and torque ratings are the same(by model).
Erv
Deep in the Heart of Texas!!
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Gray Top Corbin CedarCreek Twins Technical Talk 0 06-30-2007 05:45 AM
How to paint a gray engine black? MattTriumphs Twins Technical Talk 10 02-28-2007 05:26 PM
The fastest color is graphite gray...deal with it... jdub3 Speed Triple Forum 28 06-17-2006 01:20 PM
Gray top seat nohd4me Twins Talk 3 01-24-2006 05:48 PM
Gray Rocket JoeyF The Rocket Science Forum 15 08-24-2005 07:07 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
