Motorcycle.com
Old 01-30-2008   #1 (permalink)
Air Box Mod
After realizing that any consistent maintenance was impossible with the stock air box set up , I set out to make mine more user friendly.
I can now remove and install carbs with air box on. Or airbox by itself! After cutting off the inlet ducts I added the K&N reusable filter and a single layer of open cell air breather wrap to the outside of the filter. I will post a link to pics of the mod very soon.
Try this link for pics.
http://community.webshots.com/album/...host=community
Gr8lite is offline   Reply With Quote
Old 01-30-2008   #2 (permalink)
Favorite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
Gr8lite,
Did the same thing for the same reasons 4 years ago. Ended up buying a new airbox. Just didn't run right. The nature of the CV carbs require a ballance between vacuum, preasure, and flow to meter correctly. Here is my new air box mod. Box can be removed without disturbing carbs, and runs as good as new.
Erv
Deep in the Heart of Texas!!
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 01-31-2008   #3 (permalink)
Favorite Bike: Triumph Trophy
Other Motorcycle: Triumph Legend TT
Extra Motorcycle: Suzuki DL650
Nice mods, Erv. I've often thought that the airbox should have had a port on the end that you could unbolt, open the airbox, slide the filter out, clean it, oil it, replace it, whatever, and slide it back in, and close it up. Much like servicing an airconditioner filter in your air return of your house. It wouldn't have take anymore time to design it the way it should have been designed to begin with.
J Goertz
Birmingham, AL
Trophy4 is offline   Reply With Quote
Old 01-31-2008   #4 (permalink)
Favorite Bike: 2003 Trophy 1200
Other Motorcycle: 2001 Legend TT
Talking
Erv, Did you mean that the filter can be removed without disturbing the carbs? Your set up looks like the real deal. As has been mentioned by others this is the way it should have been designed all along. Thanks for the pics.
Flybiker
flybiker251 is offline   Reply With Quote
Old 01-31-2008   #5 (permalink)
ervdrvr1's Avatar
Trophy4, flybiker251,
You still have to remove the air box to get the filter out, it's just a lot simpler to remove the left side of the box cover and then slide the whole box out the right side without dicking with the carbs. Also, you wouldn't want a slide-in filter ala an AC system, it wouldn't be sealed very well letting dirt into the engine. I'm still looking for a good way to seal the slot in the cover where I cut it. It does suck a little dirt in there, but it's trapped by the filter so no prob. Also, the slot doesn't let so much air in that it effects the carb operation like it did when I cut the ends off like Gr8lite did. Over all it works pretty good, Triumph should have done something better from the get-go.
Happy Trails,
Erv
Old 02-01-2008   #6 (permalink)
Favorite Bike: '04 Triumph TBS
cpallen's Avatar
Other Motorcycle: '05 BMW R1200 GS
Originally Posted by ervdrvr1 View Post
[snippage] I'm still looking for a good way to seal the slot in the cover where I cut it.
[more snippage]
Happy Trails,
Erv
How about black plastic "T" Moulding - you could probably epoxy one side and trim the barbs...
Courtney
cpallen is offline   Reply With Quote
Air Box mod 1200 trophy djlnz Trophy 3 11-14-2006 06:22 AM
bonneville air box mod Bigman Twins Talk 3 05-07-2006 09:34 PM
Air box mod,problem dowop Twins Talk 10 04-19-2006 04:37 PM
K&N Filter mod/air-box mod??? Modifications & Workshop Talk 1 03-28-2005 11:27 PM
air box mod? Sprint Forum 4 11-23-2004 02:36 PM
