I think I'd have the SHOP a valve adjustment and timing check.
If those valves aren't closing just right, they leak. Leaks = lost HP
Have them adjust things, redyno
Bear in mind the factory HP rating is at the CRANK, not the REAR WHEEL. Figure a 15% loss, so about 88 rwhp stock
Got 6 Pots?
- Tokico 6 pot calipers & Gafler HH pads
- PowerBronze Shield & Pazzo levers
- Trident Exhaust, TOR & 18T front sprocket, speedo healer, 2k bars
- Skyking Frame & MV rear axle sliders, Clear Alternatives smoke tailight, 6k HIDS
