Old 01-20-2008   #1 (permalink)
what to check on an un-used bike
hello again,
my trophy has been in the garage since it went to italy and back last year (i'm based uk so it's not as exciting as most of you will be thinking!) and i'm wondering what to check or do to it to prep it for the same this summer...
gonna do an oil / filter change but i'm not too hot at mechanics but don't like paying them as i don't trust them!
i'm sure you guys will have suggestions for me... i have a haynes to guide me along.
cheers
james
millwallfcuk is offline   Reply With Quote
Old 01-20-2008   #2 (permalink)
Favorite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
james,
If everything was done to properly to put bike in storage, just follow haynes to put it back in service and everything should be ok. If not, pull plugs and put a tablespoon of oil into each cyl and turn engine over by hand to lube rings/cyl's. Check fuel/vac lines for cracks/dry rot. Check/replace battery. Check all electrical systems. Lube suspension. Check brake/clutch oil(replace if not done in last 2 years). Check tire preasure/dry rot. Check coolant(flush/replace if not done in last 2 years). If fuel was drained, fill and check carbs/system for leaks. Check carb sync. Check/lube all controls/cables. Replace fork oil if not done in last 2 years. Change engine oil/filter.
If I mist anything, it's 'cause I'm watching the NFL playoffs.
Erv
Deep in the Heart of Texas!
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 01-21-2008   #3 (permalink)
bloody hell that a lot of stuff... was thinking more like the basics... the bike starts no problem and its been on centre stand so back wheel is ok and front looks fine...
was thinking if anything may have come loose or may need checking for safety... .i'd love to be able to do all the things you suggest but i'm only learning these day!
Old 01-21-2008   #4 (permalink)
Other Motorcycle: 83 GR650 Suzuki
out of storage
Erv is giving you good advice for getting your bike back on the road.
**The most important is oiling the cylinders because the oil will have run off the cylinder walls after sitting for year(s) and you do not want the piston rings to be scraping the walls of the cylinders. It will take only a short time to build up oil pressure once the engine is started, but it could be enough time to cause engine damage.**
All the other items such as proper lubrication, hoses, coolant, tires are very important also. I am a mechanic and can do all my own work but if you are not comfortable with everything it would probably be in your best interest and safety to pay to have it done properly. If you let us know what area you are from maybe someone could recommend a good, honest mechanic you can take the bike to.
I had to do all the above on my car and bike when I returned from my tour in Germany after 2 years.
Good luck!! mcG63
mcG63 is offline   Reply With Quote
Old 01-22-2008   #5 (permalink)
i realise that - it's printed and ready to have a go....
i'm in nottingham.... last place i went was cmc and they told me a load of lies about my other bike!
check out Bike for sale stevieh1970 Twins Technical Talk 1 10-20-2007 09:43 AM
Exhaust...check, oil change...check, alarm...check rastataoist Triumph SuperSports 9 03-02-2007 06:17 PM
Check out this bike by EXILE Cycles RAYTECH Club Cafe 25 02-03-2007 08:15 PM
how can I check recalls on my bike??? Hokie Sprint Forum 2 08-07-2006 06:03 PM
Can you check your bike and let me know.... Sparti Speed Triple Forum 3 03-29-2006 02:46 PM
