Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
BikeBandit
Old 01-03-2008   #1 (permalink)
Other Motorcycle: 83 GR650 Suzuki
Question Fuel leak
I want to buy a 1200 Trophy and tonight I looked at a 2000 with only 8,000km on the odometer. The bike started fine, ran a little rough but after a couple minutes had a small puddle of gas under the bike. We shut if off, then what looked to be a mix of gas and oil started to pour out from around the left side airbox area, the end result was a huge puddle around the bike.
The owner said that he put most of the mileage on in 2000 and rode it a little last summer and had no problems with fuel leaks.
I am wondering if starting it in the cold (-11C) could be causing problems with seals, etc.
Obviously I don't want to buy a lemon but if this is a known problem with an easy fix I can probably negotiate a better price and do the work myself. Any opinions/ideas would be appreciated! Thanks, mcG.
mcG63 is offline   Reply With Quote
Old 01-04-2008   #2 (permalink)
Favorite Bike: 97 "speed trophy"
probably carb float seals leaking. happens if it sits a long time. about 55.00 a carb from bike bandit
k_dencuz is offline   Reply With Quote
Old 01-05-2008   #3 (permalink)
Trophy1298's Avatar
That or simply a split fuel line would be my first guesses with the info provided. The oil is probly from the air box. If you are not mechanically inclined and have no desire to be, you might want to pass on it. If it has been setting up for long there are a number of other issues you could face. Give me a well maintained high milege bike any day over a barn find.
If you are mechanically inclined, and the bike is at a good price it may be a fun project. These bikes are very straight forward. You can pretty much break one down and fix anything on the side of the road. Oh, and the engines run forever.
Trophy1298 is offline   Reply With Quote
fuel leak.... help! prez1374 Triumph SuperSports 9 04-13-2006 10:22 AM
Fuel Fitting O-Ring's / Fuel Leak BooneDog Speed Triple Forum 0 01-02-2006 06:34 AM
Fuel Leak bowillyard Sprint Forum 5 09-08-2005 10:26 AM
Fuel leak on RS Unsane Sprint Forum 6 07-06-2005 12:52 PM
fuel leak bigbird T3 Sport / Touring Forum 9 04-05-2005 04:36 PM
