Old 01-11-2005   #1 (permalink)
This '96 Trophy has less than 500-miles on the clock; should I be more patient and find a later model to benefit from engineering refinements ?
Also, what kind of 'recall history' should I be aware of on this model ? On the surface, the bike looks like a bargain (the seller sez $800-worth of inspections were made recently) .
I'm currently riding a '96 Adventurer, which I love . My hope is that I'll win the bidding for the Trophy. I'm hoping, also, that you 'experts' will allay my fears about making a sound decision .
Ride safe !
If it can't be fixed with duct tape, it can't be fixed !
arnoldinup is offline   Reply With Quote
Old 01-11-2005   #2 (permalink)
Keep bidding and then have the final drive gearing changed to give you less revolutions for a better cruising specification and you have a late model bike. Very few developments worth worrying about as the bikes were always well sorted mechanically.
Gidday mate!
Netmaker is offline   Reply With Quote
Old 01-13-2005   #3 (permalink)
I just bought a 96 with 750 miles on it. When I got the bike, it ran like crap. The bike had been sittingfor a couple years, and the owner just had the carbs rebuilt, and new battery($800 also). I guess the shop that rebuilt them didnt do it right, but after replacing the carbs, it runs fine. I also had to replace the petcock since it was leaking due to a dry rotted seal. One other problem I found was the tires were starting to crack.
Just some things to think about.
cs
witecap4u is offline   Reply With Quote
Old 01-13-2005   #4 (permalink)
ooobaby's Avatar
The later model (2000 and later I think) upper fairings and windshields were improved to provide better protection.
ooobaby is offline   Reply With Quote
Old 01-14-2005   #5 (permalink)
Was it just cosmetic changes between the pre '96 and post '96 models, or did they make changes to the main and subframes.
Do they all carry the heavy tubular spine?.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Old 01-14-2005   #6 (permalink)
Favorite Bike: 2000 Triumph Trophy 900
It was just cosmetic changes, reshaped the fairing a bit and the windshield is a little different. Same frame and everything else under the plastic.
Scott
Ride, Eat, Sleep, Repeat.
trophyrider00 is offline   Reply With Quote
New on here with a 96 trophy 1200 Jessechop Trophy 1 04-10-2007 09:01 AM
trophy 1200 nasusnirrad Trophy 16 01-23-2007 11:00 AM
Trophy 1200 bgfootball67 Trophy 7 08-13-2006 11:32 AM
1200 Daytona vs. 1200 Trophy? ElJugador Triumph, Models & Dealers 1 07-13-2006 12:25 PM
Anything to look out for on 95 Trophy 1200? Trophy 3 07-14-2004 02:55 PM
