BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 01-04-2005   #1 (permalink)
LaurenceWells
Hi I have a 2001 Trophy bought new and now has 8000 miles. The coils went out and were replaced under warranty. If this a recurring problem. Hope not. Love the bike. I also replaced the front tire with a new Metzler ME3 and developed a bad front end wobble at low speed. What has caused this? Is the tire bad, is it not balanced right? Any suggestions would help. Thanks
Phoenix, Az,cris_and_larry@msn.com
Old 01-04-2005   #2 (permalink)
LaurenceWells
Old 01-05-2005   #3 (permalink)
Might be something in the previous posts on wheels and tires. See 2004/08/03 and 2004/03/20 and 2003/12/08 and 2003/10/09 for posts on the issue. :???:
Gidday mate!
Netmaker is offline   Reply With Quote
Old 01-05-2005   #4 (permalink)
Gidday mate!
Old 01-05-2005   #5 (permalink)
motoworld2001
Check the steering head bearings for proper adjustment, this is the most common cause for this issue.
Tom D.
Old 01-05-2005   #6 (permalink)
motoworld2001
Tom D.
Old 01-06-2005   #7 (permalink)
Larry,
Did the wobble develop shortly after replacing the tire? I'd check air pressure first, inspect the tire for defects, confirm all fasteners are tight, and check alignment.
DaveDaniel is offline   Reply With Quote
Old 01-06-2005   #8 (permalink)
Larry,
Old 01-06-2005   #9 (permalink)
Laurence,
If the wobble only comes in at a certain speed and you can drive through it, then the culprit is probably an out of balance wheel.
But it is a process of elimination, check all of the things mentioned above.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Old 01-06-2005   #10 (permalink)
Laurence,
davie.
Front end wobble. jonkull Classic, Vintage & Veteran 2 09-24-2007 07:02 PM
Wee bit'o front end wobble? SR1 Sprint Forum 12 03-15-2007 08:41 AM
steering wobble flynbulldog Club Cafe 17 01-02-2007 05:51 PM
Front end wobble kelticwolv Sprint Forum 10 02-19-2005 09:10 PM
front end wobble cat Classic, Vintage & Veteran 1 04-24-2004 08:30 AM
