Hi Whitecap
Been reusing these foam filters for a while now. I understand originally you could buy elements but Triumph stopped supplying as they were not being fitted properly.
You may need to use sealant or mastic around the element to make sure no air bypasses the filter.
These multilayer foam filters I think are motocross technology and were meant to be cleaned and then reoiled after every meeting
Not sure if it's a special oil that is needed.
I have been using "Green" cotton air fliter oil in a pump action aerosol. The oil sprays on real thin and then I leave it a while to allow any excess to come out.
I started doing this every 12k miles but am moving onto 24k miles.
I clean the filter by pouring turps or petrol through from from the carb side only. Blowing carefully with an iraline also helps. You need to be real careful not to get grit on the carb side of the filter.
Maybe manufactures of foam filters such as Pipercross will sell a special oil??
