BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
BikeBandit
Old 09-29-2007   #11 (permalink)
Newbie
Favorite Bike: Triumph Trophy 1200
delta2565's Avatar
Other Motorcycle: Kawasaki Z1 (original)
Shimmy
Just a theory in re: to my Trophy when I found I had some handlebar shake with hands off.
I put an upgraded Hagon shock on the rear to handle my size and two up riding and 1KG Race Tech springs in the forks (didn't even change the factory fluid) after which I have not had one incident of bar shake.
I believe in my instance that my wt. plus my rider's, changed the geometry of the of the head which was causing the bar shake.
I also agree that keeping at least one hand on the bars helps, because I allowed the bike to get to the "tank slap" shake a couple of times to see how it would respond and found that just a firm grip on the bars stopped the shake w/o any undue force needed.
delta2565 is offline   Reply With Quote
Old 10-07-2007   #12 (permalink)
Well it wasn't the bend in the wheel,although framestraightsystems.com did a great job on it. Next up a new tire and recheck the head bearings,rear wheel alignment i guess.Maybe replace the front springs last. Like i said it only shakes at 45 and below.
tobyone is offline   Reply With Quote
Old 10-07-2007   #13 (permalink)
Favorite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
You can also change the fork oil to SAE15 and add an appx 1/2" to 1" preload spacer and that will help alot untill you replace the springs.
Erv
Deep in the Heart of Texas!
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 10-08-2007   #14 (permalink)
Favorite Bike: '01 Trophy 1200
I bought my 01 1200 with 4800 miles on the clock, still has the original Bridestone factory tires on it. I've put about 2500 miles on it this summer. I've noticed the shimmy more and more lately.
I'm starting to buy into the tire issue, although, it only does it when you decel not when you're coasting through 40-50 mph. I would think if it's a tire imbalance it would occur on a coast down also. I shifted into Neutral on a coast down (I don't recommend it, it's not very gentle on the trans.) and let go of the handlebars with no shimmy at all.
I'm wondering if it's some sort of engine harmonic? Has anyone paid attention to what gear you're in and RPM's. I'm curious if it does it at different combinations. If it does then I would say that's not it.
My 2 cents.
Xbubblehead is offline   Reply With Quote
Old 04-08-2008   #15 (permalink)
Well, a little update on my front end shimmy.
Two weeks ago I put new tires on my bike (Bridgestone B021) and of course balanced. The 40 mph decel shimmy is now gone. I hope it stays gone, it's a nice smooth ride again.
Old 04-09-2008   #16 (permalink)
My 900 did the same thing. It's always the tire! Don't waste the time elsewhere. IMHO.
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 07-01-2008   #17 (permalink)
update
Sorry i have not gotten back earlier.....Although I had the head bearing checked,we tighten it up some and that has eliminated most if not all of the shimmy. I would still like to up grade the forks and shock after my last 3 day ride to N. Georgia left me wanting a little better handling. I guess it will never be as good as my BMW S in that department
Old 07-07-2008   #18 (permalink)
Favorite Bike: Trophy 1200
Other Motorcycle: 1st bike, CB350
Extra Motorcycle: You have one?
Mine Did The Same
My 02 1200 did the same with the original Bridgestones from 11K to 13K miles. (I know that's alot of miles on a set, and you could actually see thread in the rear tire!). Replaced the tires with Michelins Pilot Road and the problem is gone. Can't tell you if the mechanic did anything to the steering head, but I doubt it since I wasn't charged.
[SIGPIC]Leftlane Rider (AKA OLDKID)
You're only young once, but you can be immature forever.
Leftlane_Rider is offline   Reply With Quote
Decel shimmy tobyone Modifications & Workshop Talk 2 09-24-2007 08:38 PM
Front wheel shimmy cm08 Sprint Forum 11 01-16-2007 07:14 AM
Shimmy in Front wheel - Tried everything aleka Twins Technical Talk 10 10-03-2006 06:36 PM
Tach needle shimmy at 5k? d2mini Twins Talk 7 03-21-2006 08:04 AM
new tire shimmy dunringil Hinckley Classic Triples 9 01-29-2004 05:06 PM
