Motorcycle.com
Old 08-01-2007   #1 (permalink)
Newbie
Unhappy Low speed jerkiness
Hiya guys, hope somebody has a few suggestions.
I have a real problem with my 94 1200 Trophy. I've just got it on the road again after a couple of years lay up. There is a realy bad snatching when on and off the throttle at low speed, around islands etc. The chain and sprockets are in good nick and adjusted correctly. When on the centre stand and in gear there is about 2 inches of movement on the back wheel. The rear wheel shock absorber seems OK and all the movement seems to be up front somewhere. Is there a shocker in the clutch? or have i got a lot of wear in the primary drive or gears? any ideas would be appreciated. Cheers Joe
Beezajoe is offline   Reply With Quote
Old 08-01-2007   #2 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
Hi Joe,
Some silly questions: Did you check the plugs & carbs? You may only need to give it a good run with a carb cleaner in the fuel; I use Techron in all my fuel tanks (cars, bikes, equipment etc.) If you haven't, give it some time to clean itself out before tearing into anything. Two years of sitting around is a long time and, my guess, is that the carbs need to clean themselves out.
Just the wisdom of a fool coming through: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 08-01-2007   #3 (permalink)
My wife's Trophy had a lot of hesitation and coughing at any RPM below about 2000. Ran great above 2000 RPM. Turned out to be the coils. After replacing the coils, the bikes runs great below 2000 RPM and even better all around. Best money I've spent on her bike.
Dave Arnold
'04 Rocket III
'01 Trophy 1200 (wife's ride)
La Vernia, TX
tbsrider2000 is offline   Reply With Quote
Old 08-01-2007   #4 (permalink)
Mark62's Avatar
Please explain the 2" of play while in gear on the center stand.
Mark
Mark62 is offline   Reply With Quote
Old 08-02-2007   #5 (permalink)
Newbie
Hi again,
Yes, I have replaced plugs and the carbs have been off and cleaned. I don't think its an ignition or carb problem as the engine runs great, no lack of performance although it is a little hesitant at low reves when pulling away gently - goes like stink when giving it some stick tho!.
I'm sure the problem is either gearbox or clutch, the transmition is very statchy when you open and close the throttle, its much more noticeable at slow speed and in lower gears.
I can turn the back wheel by about 2 inches when the bike is in gear on the centre stand - I would expect some play but not this amount - It almost feels as if the front sprocket is loose!
Clutch shock absorber? My haynes manual doesn't show one, but surely there must be one in there somewhere.
Hmm...
ref: low speed jerkiness Beezajoe Trophy 2 08-09-2007 07:53 AM
Low Speed Lay Down TN_Tiger Tiger Chat 14 04-15-2007 03:09 PM
S4 Low speed surge Yaros Triumph SuperSports 4 09-08-2006 10:14 PM
low speed braking loveTrumpet T3 Sport / Touring Forum 9 03-27-2006 01:02 PM
TT600 low revs jerkiness TonyS Triumph SuperSports 6 01-11-2006 04:42 PM
