Motorcycle.com
Old 07-04-2007   #1 (permalink)
Hi Folks,
Ran into an issue with my heated hand grips on my 97 trophy. I get good heat from the right grip but not the left. Might it be the heater in the grip or a wiring issue? What would be the best way to test either the wiring or the grip itself. Any short cuts would be appreciated.
Thanks,
Operators1
operators1 is offline   Reply With Quote
Old 07-05-2007   #2 (permalink)
Disconnect the defective grip from the heated grips harness and once disconnected turn on the heated grips to check that you have voltage at the wiring harness/ final connector. No voltage would indicate a wiring problem. If you have voltage, then using a low resistance ohm meter check for a resistance across the grips connecter to verify the heating coil is in tact. A zero ohm value would indicate it has failed and needs replacement.
Good luck,
GG
A pessimist is really an optimist with job experience!!
GreenGoblin is offline   Reply With Quote
1050 hand Guards and heated grips Whisperinsmith Tiger Chat 9 01-25-2008 02:17 PM
Use of BrakeAway Cruise Control on heated hand grips sodapop Sprint Forum 10 10-10-2007 10:25 PM
White hand grips? gparson5 Twins Talk 10 08-14-2007 11:37 AM
Heated hand grips switch pomallon Tiger Workshop 14 01-18-2007 07:01 AM
Hand grips wkboardr Speed Triple Forum 5 06-12-2006 11:03 PM
