This is from the Haynes Manual
900 Trophy to VIN# 4901 84mm and 10wt
900 Trophy fom VIN# 4902 to 9082 117mm (102mm max)10 wt
From VIN# 9083 to 29155 117mm (102mm max) and 15 wt
VIN# 29156 to 42274 105mm 10 wt
VIN# 42275 133mm and 10-20wt
you need to measure from the fully extended fork tube down to the surface of the oil one of the above lengths based on what VIN# you have. thats how Triumph(and everyone else I believe) do things.
Not by a specified cc's of oil.
No quarter asked, none given
