You can use ANY Propylene Glycol Coolant designed for use in Aluminum engines in a 50/50 mix with distilled water(de-ionised water if you can find it). DO NOT USE ETHYLENE GLYCOL-IT'S POISONOUS!!!!! I also don't recommend using Dex-Cool. GM is about to get a class-action lawsuit against them because of the problems GM owners are having with plugged radiators, corrosion, leaks, overheating, blown hoses, blown head gaskets etc.(
http://www.consumeraffairs.com/news0...m_dexcool.html). Personally, I use EngineIce by Cyclelogic(pre mixed with de-ionised water). But...Hey....use whatever brand you like. Just don't pollute.
Erv
