Progressive Insurance
Trident-Exhausts.comSportbikeTrackGearbritishcustomsbritishcustomsTriumphPerformanceUSAAdvanstarMotorcycleShowsShopTriumph.comAnnitori DistributingBikeBanditMotorcycle.com Classifieds!
Bike Bandit
Old 04-06-2007   #1 (permalink)
WileyOne
Really loose footpegs. Shifter side has me concerned.
I can't get to the nut behind the lowest bolt on the peg hanger plate.
SOMEbody must have a way to keep it from spinning.
There isn't enough room to get any sort of wrench in there, and the chain and gook have the nut pretty lubed up so i can't pinch it against the plate wall. I've tried wedging different things against the back of the casing, but no go.
No way to get to it from the other side or underneath, even with flexible tools.
Any ideas?
Wiley
[ This message was edited by: WileyOne on 2007-04-06 04:11 ]
Old 04-06-2007   #2 (permalink)
Favorite Bike: '98 Sprint Executive
Other Motorcycle: '01 Suzuki DRZ400
Extra Motorcycle: '70 Norton Commando 750
I think that a loose peg was the first thing that I fixed on my bike. As I recall, I was able to snug it up with a wrench half way on. I later tightened it for real by taking off the peg hanger plate, fully exposing the fastener. Put a pencil mark on the splined shifter shaft so you get the shifter assembly back on in the same place.
[ This message was edited by: sailfish on 2007-04-10 10:54 ]
sailfish is offline   Reply With Quote
Old 04-07-2007   #3 (permalink)
Favorite Bike: My '02 Trophy 1200
ervdrvr1's Avatar
Wileyone,
The best way to fix it without rounding off the nut, is to remove the whole side plate. Romove the foot peg, clean the threads, put a lock washer on, lock-tite on the threads, put it back together. Done mine a few years ago. Hasn't come loose since. Pain in the butt, but a one time fix. Right side never came loose, but did both sides anyways.
Erv
"Life is tough, but it's tougher when your STUPID!" John Wayne
ervdrvr1 is offline   Reply With Quote
Old 04-08-2007   #4 (permalink)
sixtysix's Avatar
On my 2000 1200 I was able to loosen the chain and reach the allen head bolt from behind, no problem to tighten.
Gary
Remember, we are the caretakers of mechanical art.
sixtysix is offline   Reply With Quote
Old 04-10-2007   #5 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
I was able to tighten mine using a 3/8ths drive Allen bit, 6mm I believe; I needed to use a "breaker bar" on the rear brake side and the ratchet on the shifter side. It was a "bear" to do it, what with the rear brake steady rod necessitating the use of the bar, and then having to reset the bit each time, although, the bar is able to "flex" which lets it clear some of the undercarriage parts. I didn't have to move the chain as the bit slipped over it, but it took a bit of the old "wiggle factor" to get it into the head of the bolt. Of course, the bolts are recessed into their housings so it all has to be done by "feel", and if one is descended from a long line of contortionists, that would be a big plus (I'm not).
Now if I could only meet the sadistic cretin who designed that setup........ Jim
Jim Ballard
jimballard is offline   Reply With Quote
Argh-cut off by UPS driver, bike dropped SpeedTrippy Speed Triple Forum 7 09-13-2007 12:27 AM
Coolant / Fan / Argh!! symo Speed Triple Forum 3 11-01-2006 01:42 AM
Argh! - delivery problems shane Sprint Forum 14 08-30-2006 09:54 PM
Argh the pain of it all Eddie T3 Sport / Touring Forum 2 07-02-2006 05:59 PM
Michelin pilot powers (lower the front end?) txsport06 Triumph SuperSports 16 06-27-2006 11:47 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
