Old 12-12-2006   #1 (permalink)
Sienna
Hello from another newcomer to Triumph Rat.
I recently took ownership of a 62K ’94 Trophy; purchased as a winter bike, to save the usual mount, an ageing Beemer, from further corroding through another salty UK winter.
The Trophy is a surprisingly good ride for its age and a great deal slimmer than the BM when negotiating rush hour jams. But of course with all the upside there is the downside.
I believe I have the classic Triumph alternator problem (diesel rattle). This is fairly well documented, Jack Lilley can supply the kit for a price and a day in the garage to repair should quieten everything down.
But, this evening having stopped for fuel, upon hitting the starter the bike started no problem, once the gearbox was moved from neutral to first; the engine stopped immediately. This happened 6 times ( you have to experiment to understand the problem, especially when wet, slightly cold and ever so slightly irritated with the joker in the 4X4 awaiting his turn at the pump behind you).
Having sussed this was a no go situation, I paddled the bike forward about 6 inches, started selected first, situation normal now, and rode away.
Does anyone have any clues as to the problem?
Regards
Sienna
Old 12-12-2006   #2 (permalink)
Favorite Bike: 2000 Triumph Trophy 900
Neutral switch? Check on the left handlebar and make sure it is plugged in good to the back of the clutch lever housing. My Daytona used to do that to me every now and then.
Scott
Ride, Eat, Sleep, Repeat.
trophyrider00 is offline   Reply With Quote
Old 12-12-2006   #3 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
ALSO, CHECK THE SIDESTAND SAFETY SWITCH AS WELL.
GOOD LUCK: JIM
Jim Ballard
jimballard is offline   Reply With Quote
Old 12-12-2006   #4 (permalink)
I have read somewhere on this site that the kickstand switch can play tricks like that. :???:
Gidday mate!
Netmaker is offline   Reply With Quote
Old 12-13-2006   #5 (permalink)
Trophy1298's Avatar
Ditto on the sidestand switch. And welcome to the board.
Trophy1298 is offline   Reply With Quote
Old 12-13-2006   #6 (permalink)
Sienna
Thanks for the suggestions guys, will investigate over the weekend.
Sienna
Old 01-23-2007   #7 (permalink)
Sienna
Apologies for the delay with an answer to the problem. It was as suggested ; a sticking side stand switch. Corrosion on the switch pin prevented free movement of the contacts. WD 40 and emery paper has solved the issue.
Thanks again for the comments,
Sienna
Starting problem Fortynineten The Rocket Science Forum 14 12-30-2006 12:48 PM
Starting Problem- HELP jeffkimble Twins Technical Talk 10 07-25-2006 02:12 PM
Problem Starting Andrew Trophy 7 02-25-2006 11:08 PM
05 s3 starting problem sailfish14 Speed Triple Forum 2 12-09-2005 05:10 PM
Need help with starting problem DP525 Twins Talk 3 11-22-2005 05:04 PM
