Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBanditMotorcycle.com
Old 11-18-2006   #1 (permalink)
My Trophy 1200 (02) has started sounding lumpy on tick over and stumbles when opening the throttle below 2500 rpm, it had it's 12,000 mile service 2,000 miles ago and had new spark plugs fitted. Any suggestions as to where to to start fault finding, i was thinking of checking for a loose plug lead and then carb balance?
Bob.
bobh is offline   Reply With Quote
Old 11-18-2006   #2 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
Hate to ask, but..is the choke pulling all the way off??
Start with the simplest of things: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 11-18-2006   #3 (permalink)
Fiirst thing i checked Jim,
Wots next?
Old 11-19-2006   #4 (permalink)
Coils. check it the easy way first. start a cold motor, and let it idle, spray some water on the exhaust manifold, and See if the water evaporates on all 4 cylinders at the same time.
My Photoalbum
Trophynorway is offline   Reply With Quote
Old 11-19-2006   #5 (permalink)
Check the fuel and vacum hoses and replace with a heavier wall tubing and new retaining clips, as that proved to be the solution to my roughness. The original lines use thin wall tubing, and after being subject to heat and vibration over time, do not perform as required. :???:
Gidday mate!
Netmaker is offline   Reply With Quote
Old 11-19-2006   #6 (permalink)
Tried the spraying water trick and the water evaperated a an equal rate on all four pipes. The rubber tubing and retainers all loof Ok. Checking the carb balance is next is it?
Old 11-19-2006   #7 (permalink)
Trophy1298's Avatar
Another simple question. Is the bike warmed up? Mine often stumbles if not warmed up on a cold morning.
I had a problem with the petcock once that caused the fuel flow to be restricted. At times it would cause her to stumble when I would try to open her up quickly.
Trophy1298 is offline   Reply With Quote
Old 11-19-2006   #8 (permalink)
There can be a multitude of causes.
Since his is at idles I dought if it's the vacumm line that opens the fuel petcock.
Could still be coil realted since my would be fine until I opened the throttle and cylinder presure buildt up. Other have had coils give other symptoms.
There are carb filters in the tee between each carb. Must pull the air box to get to they put this is a painful exercise.
It's been emotional
trophy_cup is offline   Reply With Quote
Old 11-20-2006   #9 (permalink)
Ah..... Now you come to mention it, the problem 1st started, almost immediately after i had the bike serviced, where it would stumble until it warmed up. At the time i put it down to not letting it warm up enough, but the problem occurs all the time now, cold or warm. IT will tick over smoothly for a few moments and then faulter. Does that give any one any more indications as what the problem might be before i start pulling things to bits. How easy is it to check the coils and can it be done with a multi meter. The haynes manual gives a few checks that can be performed but also says contact triumph dealer ££££££.
Thanks
Bob
Old 11-27-2006   #10 (permalink)
Found out the cause of the rough running, a loose connection to one of the coils. What type of spark plug are best for the trophy. The Triumph handbook and the Haynes manual quote NGK DPR 9EA-9, but mine has been fitted with NGK DPR 8EA-9. Whats the difference?
Rough running JTKMX Twins Technical Talk 1 10-04-2006 05:25 AM
new and rough running? maxed66 Speed Triple Forum 2 06-21-2006 05:39 PM
ROUGH RUNNING LOWEY Triumph SuperSports 16 04-15-2006 03:18 PM
Rough Running Anyone Spudgun Tiger Workshop 12 07-21-2005 06:45 AM
Rough Running ST Sprint Forum 7 02-08-2004 04:59 PM
