Motorcycle.com
Old 11-13-2006   #1 (permalink)
Hi guys thanks for all the info Did carbs clean out, set float levels.they were out ,Air filter dirty, Shims tight, Went for run avg speed 120kmh,2up head wind on the flat some hills not many got 45 to the gallon big difference,At wat mileage should you need to do the shims most jap bikes are aprox 20,000km ,First time working on a british bike apart from the air filter , these bike motose are good to work on , Carnt wait to do a cam chain they look so easy, you dont have to split the chain ,& the gides can be done with out having to take the head of , this has to be a good thing,Sorry guys getting carried away might go have a cold shower HAHA,Wat milage do the cam chains need replaced if at all,Cheers DJLNZ
:-D
djlnz is offline   Reply With Quote
Old 11-14-2006   #2 (permalink)
Good job djlnz, shim check ok at 20,000km,though no further. Cam chain should be checked at 50-60,000km.Triples from around 35,000 depending on the rider. Tensioner bodied and plungers are generally VERY high mileage, though the spring isn't. Spec on spring is 73mm new. The manual gives no minimum length, in my experience anything below 67-68mm indicates lack of spring pressure on the blade. The front rubbing guide is prone to fracture at its low mounting point if the chain is run loose. Bit of work their though, head has to be removed, and the liners resealed. The rear tensioner blade is the easy one. Check for stress or fracturing around the bolt mount at the base and where the plunger locates into the blade near the top..
And yes, they are good to work on!
Cheers Kerry
93-Daytona is offline   Reply With Quote
actual mpg vs computer mpg... airrider03 Sprint Forum 17 10-21-2007 02:31 PM
Help please - Date of manufacture kiwee Classic, Vintage & Veteran 8 06-25-2007 05:11 PM
Getting Maintenance up to date mpadgett Hinckley Classic Triples 3 05-09-2007 08:37 AM
Bring me up to date Cuppa500 Hinckley Classic Triples 9 12-05-2006 11:13 AM
up date on Legend ronniena Hinckley Classic Triples 0 09-20-2006 07:21 PM
