hello, not normally in here but i thought you guys probably do more miles so might know. has anyone made the shim tool from the downloads section and if so did it work ok? is the shape of the little cube that sits on the bucket to hold it down critical? ive made one not tryed it yet, the cube i made is in mild steel do you think this will be to hard and mark the buckets? thank you in advance for any help
crogger
crogger
