Hi guys just bought a trophy but didn't get a owners manual need some help
On the rev counter there is a clear wat looks to be a led light down by the bottom ,dose this do anything,Also when you turn the key on how many lights should light up,There docent seem to be a hight temp light???
Also need to know the clearances for the shims so I can check them, Is there any sites you can put me on to to buy a manual , Cheers for now
Thats for the alarm. If you dont have an alarm, the light is not in use.
And when you turn the key, there should be oil, temp and neutral and sidestand warning. I think :razz: Have to check next time to be certain
I was going to reply to this earlier and I kept forgetting after going for a ride. The only lights that come on are the nuetral, sidestand warning, and oil pressure.
