Motorcycle.com Classifieds!BikeBanditSpringfield ArmoryShopTriumph.comRacerPartsWholesaleTrident-Exhausts.comSportbikeTrackGearAdvanstarMotorcycleShows
ShopTriumph.com
Old 08-07-2006   #1 (permalink)
I have hydraulic fluid leaking from the clutch slave cylinder on my recently purhased '97 Trophy 900. Anyone have any first-hand knowledge of rebuilding one of these? Are parts serviced or do I need to buy a new assy.? Ball-park on the parts price(s)? I have a Haynes service manual on order but thought I would pick your brains first. Bike saw little use over the last few years, only has 8K, probably has moisture in the system or dried out seals. Any input would be appreciated. (I'll be flushing out the brake syatem, too) Thanks!.........MPLATT :???:
MPLATT is offline   Reply With Quote
Old 08-07-2006   #2 (permalink)
Favorite Bike: 2000 Triumph Trophy 900
MPLATT, I haven't done it before, but I looked in the sevice manual and it looks to be a fairly easy, straight-forward affair. There are only three pieces inside the slave cylinder, a spring, seal, and dust cover. All the parts are serviced so you should only have to buy what you need. Good luck with it and hope you are back on the road soon.
Scott
Ride, Eat, Sleep, Repeat.
trophyrider00 is offline   Reply With Quote
Old 08-07-2006   #3 (permalink)
Scott, thanks for the info!
Rebuild Master Cylinder on Brake or Clutch? LongRoadHome T3 Sport / Touring Forum 6 07-31-2007 01:42 PM
Used Cylinder Barrel on Rebuild HankQ Classic, Vintage & Veteran 5 10-22-2005 04:05 AM
Master cylinder leaks? Brains Hinckley Classic Triples 5 04-11-2005 03:58 PM
CLutch slave cylinder seal Slinky Hinckley Classic Triples 3 10-26-2004 04:35 PM
Oil leaking at clutch slave Trophy 2 03-25-2004 08:08 PM
