headlights acting up - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-07-2004, 01:30 PM   #1 (permalink)
I have a '96 Trophy 900 that has 12,000 miles on it.All of a sudden this year it developed a bug.Every once in a while after a ride the headlights will stay on after I shut the bike off.It is only the headlights not any of the others.Sometimes if I start the bike and shut it off a few times it will go out.Lately I've had to pull the negitive terminal off the battery.Any ideas what could be causing this I've checked the wires and can't see any chaffed.I was wondering if it could be a bad ignition switch?
thanks for any help
Old 06-07-2004, 02:16 PM   #2 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
Or the headlight relay has begun to go bad, and is sticking in the "on" mode. Just a thought.
Good Luck: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 06-08-2004, 10:10 AM   #3 (permalink)
Favourite Bike: '98 Sprint Executive
sailfish's Avatar
Other Motorcycle: '73 BMW R75/5 &'78 R100/7
Extra Motorcycle: '01 Suzuki DRZ400
Jim is probably right on the relay. I just looked at my manual and discovered that the bike has 2 relays for the headlights, one for low beam and one for high beam. Check it again and see if they'll go out on high beam. That will narrow things down considerably.
sailfish is online now   Reply With Quote
Bike Acting Up - Need Advice Bummy Twins Technical Talk 11 10-04-2007 11:55 AM
Adventurer acting up. KD5QOQ Hinckley Classic Triples 6 05-31-2007 04:31 AM
Throttle acting up again.... ROBD Twins Talk 2 06-20-2006 10:06 PM
speedo acting up porsche996 Trophy 3 01-10-2006 05:43 PM
New Trophey 1200 Acting Up aldtech Trophy 6 06-23-2004 02:40 AM
