| Trophy Trophy 3 & 4 - for all 900 and 1200cc models 1991- 2004 |
05-11-2004, 06:08 PM
250 Grand Prix Favourite Bike: 02 Trophy 1200
Posts: 107 Other Motorcycle: 1973 CB 350
Anyone using any kind of cruise control or simple throttle lock on your Trophy. I currently use a Throttle Rocker which is far from the solution but nonetheless a help on the throttle hand when running far. I am looking at my third Florida journey and I would appreciate any responses so rolling down South will be a bit easier on the hands. Does Triumph or anyone else offer this?
Finally, I appreciate the responses on my previous postings. This site was the reason my bike is finally rolling flawlessly again after the fuel starvation issues. It is a helluva resource.
Freddy
05-11-2004, 09:24 PM
World SuperBike Favourite Bike: 2002 Triumph Trophy
Posts: 2,040 Other Motorcycle: 1970 Triumph Tiger 650 Extra Motorcycle: 1999 Yamaha Virago 1100
Hi Freddy,
I'm using the Vista Cruise Control on mine, mainly because it's simple, mounts on easily and works with my heated grips. Costs around $30 and I only had to move my front brake/master cyl. in abour 1/4 inch to do the job. The universal model is what I have, although there may be a specific model available now, but I can't see the need for one. It took about 1/2 hour to do the job and it's been a god-send on the highway.
Hope this helps: Jim
Jim Ballard
05-12-2004, 10:47 PM
I use the saem sort of throttle lock that was widely used by Kawi Concours owners. It's a rubber o'ring, about 28mm dia. x 3mm dia cross-section (I think), You leave it on the bar end weight and when you want to lock the throtle you roll it into the space between the weight and the grip. It kind of sits there and provides just enough grip on the throttle to keep it from rotating, but not enough that you can't turn the throttle back and forth easily. When you want to unlock the throttle, just slide the o-ring back onto the bar end weight with the heel of your hand.
The Concours guys favored one that was a Catepiller hydraulics part, which is Cat yellow. I pilfered mine from the maintenance dep't at work but it would probably cost about $,39 at a well-stocked hardware store.
Neil
05-13-2004, 12:04 AM
I use a throttle rocker, so I sympathize with your plight. More importantly MY FIRST BIKE WAS A 1972 CB350 - lime/puke green. I miss it. And my hair. And weighing 165lbs.
05-13-2004, 09:42 AM
SuperStock Favourite Bike: 06 KTM 560 SMR (610 now)
I used the CAT o-ring last year on a longer ride on my Hayabusa, and didn't like it. It never would keep the throttle open, just slowed down the return. Oh well, for the low cost, it was worth it to see. I like the Throttlemeister design, but at over $100, its expensive. I have thought about getting one as everyone I know who has it, loves it. Still for that money I could get a few other things too. I'll probably go for the Vista Cruise in a week or 2 after I pick up my new-to-me bike. (Bet ya can't guess what I'm getting considering where I'm posting, can ya :-D )
Suck, Squeeze, Bang, Blow.
05-13-2004, 04:52 PM
Thanks for the input. A couple of options are certainly better than my current setup. Sounds like the Vista Cruise may be the way to go.
07-14-2004, 09:09 AM
My 95 had a throttle lock on it when I bought it, so I don't know much about it. On my 2003, however, there appears to be a small, rectangular plate right where it would've been on my 95. Kinda makes me wonder if it was intended for a throttle lock.
JRave
Life is short, ride it hard.
07-14-2004, 03:46 PM
I finally ordered the NEP Cruise Control from Aerostitch. $19. We'll see how it is when it arrives.
07-19-2004, 04:16 PM
gararnett,
Let me know how it works. I was leaning towards the Vista Cruise but ran into a rider with a Throttlemeister on his Sprint and between the ease and the effectiveness it is quite a setup. Cost is high, however. Have to get one soon, my long summer journey is coming up.
good riding,
Milw Freddy
07-19-2004, 05:22 PM
The NEP came in Friday, and I have not installed it yet. I got an e-mail from someone who installed the std. Vista Cruise, not the universal, and said they cut off the tabs, such that it doesn't matter if you get a single cable or dual cable model. the NEP is made very similar to the standard Vista, so I'm trying to see how it was modified to work. As it is, the NEP will not work (I have the dual cable model, as I screwed up in ordering, but I don't think the dual model would work either with out modofocation as the tabs are just too high to work on the throttle housing. So, since the Vista std. and NEP are similar, I wanna see how the Vista was modded to work. If I can do the same with the NEP, that will great. Hoping to get the info soon as I'm hoping to make a long ride either this coming weekend or the next.
I will post results. Just don't really have any yet.
