After compressing one side of the caliper's pistons, put a new pad or piece of wood in there to keep them from coming out when you do the other ones. You could open the bleeder which would remove the pressure as you push them back, but then you've got to deal with the extra work of rebleeding the brakes, etc. Just make sure that the pistons haven't "cocked" themselves which would make it hard to push them in until they straighten out.
Hope this helps: Jim
[ This message was edited by: jimballard on 2004-05-08 19:14 ]
Jim Ballard
