Remove the chin panel. Look up on the left side of the wiring harness, forward of the fuse box (as you are facing the front of the bike)...There is a black colored, waterproof, female connector.
On the 900's, it is connected to the number 4 fuse (10 amp).
I beleive this connection is also off when the ignition is off.
(haven't tested it)
The connection is designed for the Triumph heated grips... You could cut the existing connector off and use your own male/female connector...because you'll never find that male connector! (But if you do, let me know!)
FYI- The right side of the wiring harness has the connections for the alarm/imobilizer.
Hope this helps.
Sean
