Fork oil level - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 06-21-2013, 04:58 AM Thread Starter
Fork oil level
OK, FINALLY got my fork seals sorted and after reading posts on this forum, decided to insert a 3/4 inch spacer and fill the forks to 125mm below top of forks (compressed)
Struggled like crazy to insert the spacers and finally gave up and used just the standard triumph one. However, forgot to drain some oil out of the forks before putting them back together. The forks seem pretty damn stiff now, but is this just because they are rebuilt with new seals/oil or is it because the air gap is wrong?
Simon
'97 900cc trophy, Showa forks.
Ooops, forgot, I've also used 15w fork oil which is thicker so I guess that may be contributing....
simonjrwinter is offline
post #2 of 4 (permalink) Old 06-22-2013, 01:22 AM
Main Motorcycle: 2001 Trophy 1200, T509
Other Motorcycle: Norton Commando MK 3
Extra Motorcycle: 1968 BSA Thunderbolt
15w fork oil would't be too heavy, book calls for 10w20 so 15 seems right there, and new seals definately would have nothing to do with increased stiffness. My factory manual is showing an air gap of 133mm for Showa equipped Trophys though. Too high a fluid level will stiffen up the fork action.
rubber biscuit is offline
post #3 of 4 (permalink) Old 06-22-2013, 06:17 AM
Main Motorcycle: Rebuilt 1993 Trophy 900
alexibrow's Avatar
The 15w oil is contributing if factory spec is 10w; however, RB is right in that a smaller air gap also stiffens things up. It's likely to be a combination of the two "modifications".
Bear in mind that as well as stiffening the forks, thicker oil slows down the bound and rebound, so the forks are slower to react to changes in the road surface.
Sent from Motorcycle.com App
alexibrow is offline
post #4 of 4 (permalink) Old 06-22-2013, 11:05 AM
Main Motorcycle: Triumph Trophy 1200 94
henwilv's Avatar
Other Motorcycle: 1200 Trophy 96, Laverdas
Extra Motorcycle: Honda 750 F2 82
stiffening up the fork a bit doesn't sound like a bad idea to me, it's pretty soft in std. trim
henwilv is offline
Fork oil level recommendations.Progressive Fork Spring installation SST Cruisers - America, Speedmaster 2 05-17-2012 01:00 PM
Fork Oil and Oil Level for Race Tech Spring StreetTripleDan Air Cooled Twins Technical Talk 3 03-07-2012 05:00 PM
Fork oil level rf9rider T3 Sport / Touring Forum 8 08-09-2010 10:55 AM
fork oil level delrazor Classic, Vintage & Veteran 10 07-14-2009 07:08 AM
Fork Oil - Increasing viscosity and oil level? NikosR Sprint Forum 9 04-21-2007 04:12 PM
