Intermitten Clock - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-27-2004, 08:15 AM   #1 (permalink)
OK, one last "problem". The clock on my '99 works when it want to. It will be dead when I start out but after a little while it starts working. I'll reset it and it's fine for the rest of the day. The next morning I'll discover it stopped again. I've wiggled the wires behind the clock and that doesn't do anything. The fuses are OK.
Am I missing something or is it new clock time? :???:
Old 04-27-2004, 08:31 AM   #2 (permalink)
Sounds as though your battery could be at fault, after a run it's providing more charge ? :???:
AndyA is offline   Reply With Quote
Old 04-27-2004, 12:11 PM   #3 (permalink)
I thought it might be too so I put a charger on it and it showed full charge. Could be a dead cell though. I'll look into that.
Old 04-27-2004, 02:55 PM   #4 (permalink)
The battery it is!!! Even though the charger showed full, there was some crud around the terminals and after cleaning them, the clock works again!!
There was apparently enough juice to start the bike just fine but not to keep the clock running after it stopped for a while.
Old 04-29-2004, 01:26 PM   #5 (permalink)
Well, $65.00 and a new battery latter - it wasn't the battery. There is a plug that I happen to feel around for on the very top of the clock that was loose. I've played around with it and got it working but if it stops again, I'll have to take the front of the fairing off and fix it correctly.
[ This message was edited by: iridehorses on 2004-04-29 11:28 ]
Old 04-29-2004, 05:03 PM   #6 (permalink)
Fingers crossed that you've found the problem Bill
Old 04-29-2004, 06:26 PM   #7 (permalink)
Favourite Bike: 2000 Triumph Trophy 900
My clock did the same thing. Took the upper fairing off and unplugged the connectors to the clock, cleaned them and also tightened them up. Seemed to do the trick.
Scott
Ride, Eat, Sleep, Repeat.
trophyrider00 is offline   Reply With Quote
The best alarm clock! L0KI Speed Triple Forum 10 10-12-2006 06:41 PM
Clock lamps BlueTbird Hinckley Classic Triples 0 09-20-2006 11:54 AM
No clock or tripmeter ColinHitchcock Tiger Workshop (archive) 5 09-14-2006 06:11 PM
Intermitten problem when hot woodenindian Speed Triple Forum 3 05-29-2006 08:32 PM
CLOCK Sprint Forum 2 04-07-2005 01:09 PM
